Short On Cache
 Trim and Tach
i have a PD has anyone run their trim switch and tach up to their grab bar? Id like to have it there so I can trim the motor while facing forward. I really wouldnt mind having a trim switch on there and on the control panel. Is that possible?
_________________ The nation that makes great distinction between its scholars and warriors will have its thinking done by cowards and its fighting done by fools.-Thucydides It is the Soldier that salutes the flag, Serves beneath the flag, Who's coffin is draped with the flag and allows the protestor to burn the flag.-Unknown Greater love has no other than this that he lay down his life for his friends. John 15:13
Thu Aug 04, 2011 2:11 pm |
Team Camo
 Re: Trim and Tach
Yep, somebody posted about it a while back.
Thu Aug 04, 2011 5:43 pm |
Short On Cache
 Re: Trim and Tach
I search it thanks
Thu Aug 04, 2011 6:04 pm |
richard nagon
 Re: Trim and Tach
it can be done but you will need to use relays. their trim uses a ground to switch power back and forth. go to a boat salvage and find a old merc tilt and trim relay pack and you will be good to go. the only one out their that doesn't need a relay pack is the m.b. with the merc tilt trim unit.
_________________ JUST ANOTHER FARMER ON WELFARE
Thu Aug 04, 2011 6:59 pm |
Short On Cache
 Re: Trim and Tach
Good info. thanks!
Sat Aug 06, 2011 9:02 am |
Wilson
Joined: Thu Jan 15, 2009 6:35 pm Posts: 935 Location: South LA
 Re: Trim and Tach
I could be wrong but I don't think they use relays. Just a really heavy duty switch. Sportsman's Guide has a heavy duty outboard trim switch, like you put up front by the trolling motor, that a lot of people have been using with goog success. That way you can mount it on the handle right behind the twist throttle. Use the search feature because there was a good thread that covered this. I think it was Coastal's idea.
Sun Aug 07, 2011 3:30 am |
richard nagon
 Re: Trim and Tach
if he is going to run two switches he will need a relay pack. u have to take away the ground from the other switch or he will have to grow a third arm.  on my older engine i bought my merc trim relay pack at a boat salvage for 15 bucks and i also got the little trim switch off the cowling off of two motors and mounted a trim on the bow and one on the blower housing so i can trim up and use the mudbuddy side mounted lock system that way i don't have to reach foward to the tiller handle to lock it or unlock it on my new engine. on the new mudbuddys with the merc trim u don't need a relay pack u can mount as many trim switches as u want.
Sun Aug 07, 2011 6:51 am |
Short On Cache
 Re: Trim and Tach
Does it matter that I am running a PD? Also, any idea what the thread was called on this subject, I cant find it
Sun Aug 07, 2011 8:58 am |
Team Camo
 Re: Trim and Tach
Sun Aug 07, 2011 9:12 am |
