Trim and Tach http://mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=20654 |
Author: | Short On Cache [ Thu Aug 04, 2011 2:11 pm ] |
Post subject: | Trim and Tach |
i have a PD has anyone run their trim switch and tach up to their grab bar? Id like to have it there so I can trim the motor while facing forward. I really wouldnt mind having a trim switch on there and on the control panel. Is that possible? |
Author: | Team Camo [ Thu Aug 04, 2011 5:43 pm ] |
Post subject: | Re: Trim and Tach |
Yep, somebody posted about it a while back. |
Author: | Short On Cache [ Thu Aug 04, 2011 6:04 pm ] |
I search it thanks |
Author: | richard nagon [ Thu Aug 04, 2011 6:59 pm ] |
it can be done but you will need to use relays. their trim uses a ground to switch power back and forth. go to a boat salvage and find a old merc tilt and trim relay pack and you will be good to go. the only one out their that doesn't need a relay pack is the m.b. with the merc tilt trim unit. |
Author: | Short On Cache [ Sat Aug 06, 2011 9:02 am ] |
Good info. thanks! |
Author: | Wilson [ Sun Aug 07, 2011 3:30 am ] |
I could be wrong but I don't think they use relays. Just a really heavy duty switch. Sportsman's Guide has a heavy duty outboard trim switch, like you put up front by the trolling motor, that a lot of people have been using with goog success. That way you can mount it on the handle right behind the twist throttle. Use the search feature because there was a good thread that covered this. I think it was Coastal's idea. |
Author: | richard nagon [ Sun Aug 07, 2011 6:51 am ] |
if he is going to run two switches he will need a relay pack. u have to take away the ground from the other switch or he will have to grow a third arm. ![]() |
Author: | Short On Cache [ Sun Aug 07, 2011 8:58 am ] |
Does it matter that I am running a PD? Also, any idea what the thread was called on this subject, I cant find it |
Author: | Team Camo [ Sun Aug 07, 2011 9:12 am ] |
Take your pick. search.php?keywords=trim+on+grab+bar&terms=all&author=&sc=1&sf=all&sk=t&sd=d&sr=posts&st=0&ch=300&t=0&submit=Search |
