Joined: Thu Mar 26, 2009 1:53 pm Posts: 77 Location: DE, MD, NJ
help please!
Hey guys I am trying to take the yoke off of the crank on a vanguard with a 1 inch keyed shaft. Any one have any ideas as to how I can pull it off?? Thanks guys!
_________________ 1544 G3 with 23hp GDLT
Sun Aug 14, 2011 12:55 pm
spearfish1976
Joined: Wed Aug 03, 2011 2:48 pm Posts: 50 Location: New Orleans
Re: help please!
Lube it up first. Then just loosen the set screws and tap it off. If you can remove the key from the keyway first that will allow you to rotate the yoke on the crank. It may help get it off.
Good Luck!
_________________ Rogue 16X38 w/ a 18hp Copperhead
Thu Aug 18, 2011 4:22 pm
drinkbackerz
Re: help please!
Thu Aug 18, 2011 8:58 pm
da go get'er
Joined: Wed Oct 27, 2010 8:30 am Posts: 3406 Location: Prairieville
Re: help please!
can you get a gear puller around it? I'd try that before beating it if you can make it work. and as with most things its always better to lube it first
_________________ 17*38 Klibert 23GDLT I toast to staying positive and testing negative!
Users browsing this forum: Majestic-12 [Bot] and 84 guests
