help please! http://mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=21001 |
Author: | whitelightning [ Sun Aug 14, 2011 12:55 pm ] |
Post subject: | help please! |
Hey guys I am trying to take the yoke off of the crank on a vanguard with a 1 inch keyed shaft. Any one have any ideas as to how I can pull it off?? Thanks guys! |
Author: | spearfish1976 [ Thu Aug 18, 2011 4:22 pm ] |
Post subject: | Re: help please! |
Lube it up first. Then just loosen the set screws and tap it off. If you can remove the key from the keyway first that will allow you to rotate the yoke on the crank. It may help get it off. Good Luck! |
Author: | drinkbackerz [ Thu Aug 18, 2011 8:58 pm ] |
Author: | da go get'er [ Thu Aug 18, 2011 9:29 pm ] |
can you get a gear puller around it? I'd try that before beating it if you can make it work. and as with most things its always better to lube it first ![]() |
