It is currently Thu Jul 17, 2025 1:28 pm
Reply to topic  [ 4 posts ]
 help please!
Post help please!
Hey guys I am trying to take the yoke off of the crank on a vanguard with a 1 inch keyed shaft. Any one have any ideas as to how I can pull it off?? Thanks guys!
1544 G3 with 23hp GDLT
Sun Aug 14, 2011 12:55 pm
Post Re: help please!
Lube it up first. Then just loosen the set screws and tap it off. If you can remove the key from the keyway first that will allow you to rotate the yoke on the crank. It may help get it off.
Good Luck!
Rogue 16X38 w/ a 18hp Copperhead
Thu Aug 18, 2011 4:22 pm
New Member
Thu Aug 18, 2011 8:58 pm
can you get a gear puller around it? I'd try that before beating it if you can make it work. and as with most things its always better to lube it first ;)
17*38 Klibert 23GDLT
Thu Aug 18, 2011 9:29 pm
Users browsing this forum: Google [Bot] and 162 guests
