It is currently Wed Jul 16, 2025 9:08 pm
Reply to topic  [ 10 posts ]
 HOOKED BOAT VS SMOOTH
Post HOOKED BOAT VS SMOOTH
what is the performance difference between a completely slick bottom verses one that has dips and valleys in it, for instance on a 54 inch wide bottom boat. We using it only for hunting purposes, have not ran it yet, picking up a gtr 35 this week for it. Repainted it today and while painting noticed the dips or valleys in the bottoms between the interior ribs.
thanks
brianb
gtr35 gt 1854 / w gatorglide
12 ft 11hp longtail
14 ft 10 hp longtail
Merc 225hp TR20
Tue Aug 30, 2011 8:25 pm
Post Re: HOOKED BOAT VS SMOOTH
If the boat has horizontal (side 2 side) bracing, that washboard effect will slow you down & somewhat hinder performance.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Tue Aug 30, 2011 8:28 pm
which way do the ribs for the bracing run?
If the bracing is front to back, then really only the dents right at the transom that create a wedge will really hinder the boats performance.
Tue Aug 30, 2011 8:29 pm
it is a gt1854, has mostly ribs running the length of the boat but a couple crossing it also
12 ft 11hp longtail
Merc 225hp TR20
Tue Aug 30, 2011 8:31 pm
You should be fine as long as they a running along the boat and not across
Tue Aug 30, 2011 8:33 pm
The "tunneling" won't hurt your performance. That's why they build these boats the way they do.
You can still get a "hook" back by the transom though. Anywhere that water can cavitate or run in to resistance can cause problems.
Tue Aug 30, 2011 8:34 pm
Unless the dents are right up against the transom, you shouldn't really even be able to tell the difference. If they are near the transom, it'll cause the boat to want to plow instead of plane out.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Tue Aug 30, 2011 8:36 pm
echo...echo...echo...
Tue Aug 30, 2011 8:37 pm
so what is the main cause of the hook, running over stumps / logs etc or just over time this happens
12 ft 11hp longtail
Merc 225hp TR20
Tue Aug 30, 2011 8:38 pm
Tue Aug 30, 2011 8:39 pm
Users browsing this forum: No registered users and 94 guests
