It is currently Sat Feb 14, 2026 4:50 pm
Reply to topic  [ 16 posts ]
 Gator Tail Props and Gears
Post Gator Tail Props and Gears
Is there a better prop out there for a gator tail other than the factory big blade? Looking for something that I can get a little more speed yet still get through the mud. I don't really care to try to dig myself off a wet mudflat, just enough to get going in a inch or two of water with soft mud.
Also, what is the best gear ratio setup for the gator tail? I believe I remember seeing where the EVT guys tried some different gearing but can't remember the results.
This would be on a gator tail with a stage 1 and cam.
Wed May 13, 2009 9:26 pm
Post Re: Gator Tail Props and Gears
stay with stock gears, (thats what i ran 42 with) prop wise i think the big blade cant be beat, best all around prop they make, tryied to repitch some didnt really make a diff.
Wed May 13, 2009 10:04 pm
Location: Drive East until somebody gives you the finger, then drive five hours North.
If you're not carrying a load, you may want to ask them about a small prop. My small prop runs faster than my big prop, but doesn't carry a load nearly as well.
"Hey! Hey, you little forest creatures! None of you sons of bitches try to be heroes!"
"Once I ate leftover chinese that had been kept in an unsealed container and I experienced complete awareness."
Thu May 14, 2009 1:42 pm
nice avatar C_F, really nice :D
is dat de lady prathertown wit 2 rockin chairs?
Thu May 14, 2009 4:58 pm
Fri May 15, 2009 6:03 pm
It's been two years since thay came out with the ... just rite prop !!! It's not the "big" blade and its not the small "speed" one either ...... it's in the groove ....... don't type that thay quit it .. 'cause I mite need another one !!!!! Dag-Gum it !!!!! Please don't tell me thay quited somethin' that worked good !!!!! :shock:
Fri May 15, 2009 9:49 pm
17x48 extreme stage 2 GTR
Sat May 16, 2009 4:36 am
Thanks fo the reply on that DDM .... !!! Thay mite be sumthin' better to come along ..... but I's shore like that propeller !!!! :D
Sat May 16, 2009 8:37 pm
I was under the impression there was a standard prop, then Gatortail came out with the big blade, now stock on new motors. Is there a larger prop still? I bought my GTR35 in 2008, with a 12" prop.
Sun Jun 07, 2009 1:51 pm
Sun Jun 07, 2009 2:08 pm
If you need a little more prop find someone with a mudbuddy and try their big blade. Its got 1/2 inch more pitch and is just a little larger diameter. May give you a little more.
Repitching a prop can make a big difference, 10 pitch is always 10 pitch.
Sun Jun 07, 2009 3:39 pm
Sun Jun 07, 2009 7:21 pm
Mon Jun 08, 2009 6:01 am
A hook in the hull would cause you to lose speed while maintaining the same rpm's.
Mon Jun 08, 2009 4:13 pm
Mon Jun 08, 2009 4:21 pm
Mon Jun 08, 2009 9:36 pm
