Quacker Jacker
Joined: Wed Jan 21, 2009 11:15 am Posts: 39 Location: Brandon, MS
 Thin hydroturf?
I noticed the hydroturf.com website is selling some of the "gator boat brown" turf as well as nat gear. I'm assuming this is the same exact color etc that you can get from gator trax. Only thing is that in the description it says that this turf is thinner than their other kinds (5mm instead of 5.5mm). I was wondering if yall knew what kind gator trax actually used on their boats?
I'm ordering a bunch of "B" stock today and wanted to throw in some brown with it to save on shipping, but if its thinner than the kind gator trax uses or that yall use then i'll just wait and order it from somewhere else.
| Fri May 22, 2009 8:00 am |
The Shafer
Joined: Tue Jan 13, 2009 7:46 pm Posts: 1947 Location: Longview. TX
 Re: Thin hydroturf?
can you even notice 1/2 of a millimeter?
_________________ WC 1848 Bateau w/ 36 PD FPR
| Fri May 22, 2009 8:12 am |
Quacker Jacker
 Re: Thin hydroturf?
probably not. But the description from hydroturf says "sheets are slightly thinner and less dense than our 40"x 62" sheets. This means they are softer and not quite as durable. Use of heavy boots may cause wear or tearing"
kind of like they are trying to say its not durable?
| Fri May 22, 2009 8:15 am |
stanco
 Re: Thin hydroturf?
if you are worried about that, AND want to get it inexpensive..
I think their gray diamond pattern runs $60 if they havent changed the price. Tough as nails for their gray, its even better than the camo 'line' pattern as far as durability (per them).
| Fri May 22, 2009 9:09 am |
tongthrower
Joined: Wed Jan 14, 2009 8:36 am Posts: 672 Location: Houston, TX
 Re: Thin hydroturf?
_________________ EVT Stage 1 32PD on a 17x48PD "I'm not a Republican because I grew up rich. I'm a Republican because I did'nt want to spend the rest of my life poor. Waiting for the goverment to rescue me." Mike Huckabee
| Fri May 22, 2009 12:00 pm |
deadbird8
 Re: Thin hydroturf?
| Fri May 22, 2009 12:37 pm |
white1
 Re: Thin hydroturf?
I bought some. Ill let everyone know when it starts Fing up
_________________ Just your basic cracka ass cracka
1840 gator tail with 35GTR 15xx Bateau with 15 honda
| Fri May 22, 2009 7:48 pm |
Benny
Joined: Tue Apr 28, 2009 11:12 pm Posts: 23 Location: Idaho/Montana
 Re: Thin hydroturf?
I had them send me a sample of the rejected stuff. I compared it against a sample of A grade stuff and it is not as strong. I cut it with knives, embedded hooks in it and tore it. I did the math and if you get it with adhesive backing it is $.01 square inch cheaper for the reject stuff. I also measured my boat and I would need to get three sheets no matter which size so it's an easy decision to get the good stuff.
| Sat May 23, 2009 11:16 pm |
idabilly
Joined: Sat Jan 17, 2009 7:17 pm Posts: 617 Location: Idaho
 Re: Thin hydroturf?
| Sun May 24, 2009 10:29 am |
