It is currently Wed Jul 16, 2025 3:04 am
[ 8 posts ] |
PD HYDRO TRIM INSTALLATION
canvasbackdrake
Joined: Mon Mar 22, 2010 8:44 pm Posts: 140 Location: Pearland, TX
NEED A LITTLE HELP HERE, do you think MY X2 PRO DRIVE BOAT transom has enough room to install the pump without offsetting it to the side.Is a 2009 model. Since I don't have a brace in the middle I was told I may have to offset or weld one. Thanks for the help.
Thu Sep 29, 2011 4:51 pm |
cb5331
 Re: PD HYDRO TRIM INSTALLATION
That brace looks low enough, but it's hard to tell. We had to offset on my dad's last boat, but the hoses they came with were long enough. Wasn't a big deal.
Thu Sep 29, 2011 4:59 pm |
greg f
Joined: Sat Feb 05, 2011 10:02 pm Posts: 490 Location: Mexifornia
looks like you have room.
Thu Sep 29, 2011 5:03 pm |
meterman3
i would try to put it under the corner brace out of the weather and sun plastic will last a lot longer that way
_________________ driving a gd in ur lake and i aprove this message
Thu Sep 29, 2011 5:06 pm |
the gator
Joined: Tue Sep 06, 2011 5:23 pm Posts: 190 Location: Patterson,LA
yes anyone of the vertical channels is where they install them.
_________________ 35gtr Stage 1 On 19'3"x46" Mad man Hull going Places far and beyond
Thu Sep 29, 2011 6:29 pm |
canvasbackdrake
Does the pump just install on the PD bracket where the pre drilled holes are at? Or do you also bolt it on the boat? If it needs to be offset do I use self tapping screws to put on the brace. Thanks for the help again.
Thu Sep 29, 2011 8:56 pm |
POKER1
Thu Sep 29, 2011 9:09 pm |
canvasbackdrake
I got a measurement of 13.5 in of clearance from where you bolt the trim on the motor to where the middle brace starts (see the pics).Can someone give me a measurement of the entire unit. I think I was told I needed a 12 inch clearance? I just want to verify, before I ordered it, thanks again!
Fri Sep 30, 2011 8:34 pm |
[ 8 posts ] |
Users browsing this forum: kib876 and 87 guests |
