Saltwater
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=23602
Author:  Gauge [ Mon Oct 31, 2011 6:12 pm ]
Post subject:  Saltwater
I run a GD LT 23hp with a 1648 tracker. My question is what affect will the salty air and saltwater have on my boat if I take it hunting on the coast? I plan on hosing it down, corrosion Xing and WD40ing the heck out of it. Is there anything else I should do? What kind of rusting precautions do you take before and after a trip to the coast/saltwater.
Author:  WestEndAngler [ Mon Oct 31, 2011 6:15 pm ]
Post subject:  Re: Saltwater
I just rinse mine :lol:
Author:  JIMMY W [ Mon Oct 31, 2011 6:29 pm ]
The last 2 guys here that I know that are running godevils in this area spray them down with Corrosion X
Author:  slingshot [ Tue Nov 01, 2011 4:28 pm ]
Bro 99.99% of the time I run the salt all year fishin and huntin just a good washin will be fine with a silcone spray after. I have no rust.
Author:  bayouboy [ Tue Nov 01, 2011 4:58 pm ]
With all that said, If you do run salt water and do not do maintanance on it afterwards then you will end up with one big pile of rusty shit! that probably won't run! I've seen a lot of out of towners run their rigs during opening season then throw it straigth into a boat shed. They come back for the second slpit and it literaly looks like a 10 yr old motor turning to dust!
Author:  Gauge [ Wed Nov 02, 2011 1:12 pm ]
Author:  WestEndAngler [ Wed Nov 02, 2011 1:15 pm ]
Author:  Gauge [ Wed Nov 02, 2011 1:45 pm ]
Thanks WestEnd!
Author:  da go get'er [ Wed Nov 02, 2011 2:11 pm ]
used motor oil mixed with wd 40 in a spray bottle. 25% oil to 75% wd 40 ratio. Buy the wd by the gallon. Will last a long time.
Author:  swampmonkey [ Wed Nov 02, 2011 3:56 pm ]
Boeshield T-9 Rust & Corrosion Protectant Aerosol Spray, 12 oz - good but expensive.
had the crap in my throttle cable over the big freeze jan '10 & didn't have any problems & my friends had lock up....basically bath the engine w/ the shiot
Author:  Gauge [ Thu Nov 03, 2011 5:13 am ]
Is there anywhere on the engine you are not supposed to spray anti-corrosion spray??
Author:  med [ Thu Nov 03, 2011 5:47 am ]
I wouldn't spray it in the muffler. ;)
Author:  MaXXis85 [ Thu Nov 03, 2011 5:58 am ]
A good hose down and some WD40 works well. Like BB said, if you ignore it over time your going to have a mess.
Author:  pooldoo73 [ Thu Nov 03, 2011 7:12 am ]
Corrosion-X is good on everything. Electrical, metal, u name it. U can also get the HD Corrosion-X. It goes on as a thick film that doesn't dry. It is the ultimate in protection, u just have to use a steam cleaner r alcohol to remove it. Did I say it never gets hard. I spray my big engines down with it on my offshore boat.
Author:  swampmonkey [ Thu Nov 03, 2011 9:21 am ]
Author:  kibb [ Thu Nov 03, 2011 9:40 am ]
Where y'all getting corrosion x locally?
Author:  pooldoo73 [ Thu Nov 03, 2011 10:48 am ]
Big cans from academy.
Author:  Gauge [ Thu Nov 03, 2011 12:05 pm ]
Author:  coastal [ Thu Nov 03, 2011 12:51 pm ]
Give it a good rinse with fresh water and spray the entire engine.
[youtube]http://www.youtube.com/watch?v=yH5trE3tbdg[/youtube]
Author:  kibb [ Thu Nov 03, 2011 12:59 pm ]
Author:  Wilson [ Thu Nov 03, 2011 7:07 pm ]
I've been using Corrosion X in the red can for years. Lately I've found that it leaves a residue that can collect some dirt over time, especially when I spray it on my Mikuni carb . Anyone else seen this?
