It is currently Mon Jul 14, 2025 12:54 am
Reply to topic  [ 1 post ]
 Transom Cracking, Best Practices
Post Transom Cracking, Best Practices
I have noticed my transom cracking. I think it's from hauling the boat around on the trailer. The trailer seems to bounce hard on the highway instead of absorbing the bumps in the springs. I have a 17' Southfork flat with a 27 HP Beavertail Surface Drive. I have dropped the axle and pulled apart the springs. Every bolt and nut are corroded. I will be replacing everything with stainless. After I test that I'll see if I need to remove a leaf. I found a transom saver that I modified to work with the surface drive chassis and will be using that going forward. Anything else here I should be doing? I have already had someone weld additional supports to brace the motor inside the boat.
Mon Jan 09, 2012 10:59 am
Users browsing this forum: No registered users and 70 guests
