Gtr breather nut comming loose http://mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=27007 |
Author: | Bayoubandit [ Tue Feb 21, 2012 10:58 pm ] |
Post subject: | Gtr breather nut comming loose |
Ok so Ive got new rig and everytime I run it the damn big plastic nut that holds the breather cover on backs off!! Whats the quick fix. When it gets loose it starts rattling and it's driving me nuts. I have cranked the shit out of it and it still vibrates loose! 35gtr. I dont want to be looking for my cover on the side of the road!! |
Author: | Woodiebuster [ Tue Feb 21, 2012 11:02 pm ] |
Post subject: | Re: Gtr breather nut comming loose |
Drill a hole through both sides of the cover and zip tie them together would be an easy solution. |
Author: | Bayoubandit [ Tue Feb 21, 2012 11:08 pm ] |
I'm thinkin about drilling a hole through the nut and cover where it overlaps and putting and pin or somthing in that rig |
Author: | autogateman [ Tue Feb 21, 2012 11:14 pm ] |
uhhm, a lock washer? |
Author: | Bayoubandit [ Tue Feb 21, 2012 11:19 pm ] |
No place to put a lock washer. The nut doesn't bottom out on anything. It the big plastic nut with a nut inserted into it that holds the plastic over on. |
Author: | T-Bubba [ Tue Feb 21, 2012 11:20 pm ] |
blue loctite |
Author: | Team Camo [ Tue Feb 21, 2012 11:22 pm ] |
Use some LocTite on it. I see you're in LC, you should head over here to Port Neches Saturday & see what that motor can do. |
Author: | jakecologne [ Tue Feb 21, 2012 11:22 pm ] |
Bungee cord over the top lol |
Author: | Bayoubandit [ Tue Feb 21, 2012 11:26 pm ] |
Author: | Team Camo [ Tue Feb 21, 2012 11:30 pm ] |
Look at the SETX mud run 2012 forum. |
Author: | marsh mule [ Wed Feb 22, 2012 3:57 am ] |
Use some duck tape. Cause if you can't duck it..... ![]() ![]() |
Author: | skinnerton_outlaw [ Wed Feb 22, 2012 8:00 am ] |
Mine does the same thing. I have to bow up on it, I mean really twist that SOB, then it wont come loose. |
Author: | msm8281 [ Wed Feb 22, 2012 8:08 am ] |
Author: | dguidry [ Wed Feb 22, 2012 8:10 am ] |
I am the expert on this. Have replaced 3. I screwed the top to the base with 2 self tapping metal screws. |
Author: | WestEndAngler [ Wed Feb 22, 2012 8:16 am ] |
Author: | DeathMetalDukk [ Wed Feb 22, 2012 5:17 pm ] |
Author: | radikkle [ Wed Feb 22, 2012 7:27 pm ] |
Author: | Bayoubandit [ Wed Feb 22, 2012 10:25 pm ] |
Put blue locktite today with channel locks. Guess we will see! |
Author: | DVR [ Wed Feb 22, 2012 10:40 pm ] |
I trailer 800 miles each way. Duct tape all the way. 4800 miles and 40 something total running hours on two different motors this year. |
Author: | wireworks [ Thu Feb 23, 2012 7:33 am ] |
After loosing the first one on my Pro Drive I over tightened the next one. Then the stud broke and I lost the bracket, filter and cover. Now I have a 6 in. piece of duct tape taped over the nut and it can't turn. Working great so far, cheap and quick too. |
Author: | marsh maniac [ Thu Feb 23, 2012 6:37 pm ] |
jamb nut |
Author: | autogateman [ Thu Feb 23, 2012 6:42 pm ] |
what about teflon tape on the threads?? |
Author: | Bayoubandit [ Fri Feb 24, 2012 4:54 pm ] |
So far blue loctite is doing the job. Ran it about 3 hours this morning with no probs |
Author: | bayouboy [ Sun Feb 26, 2012 6:01 pm ] |
Wow, First off if you tighten it to tight it will snap the bolt and you will loose everything but the main backing plate like mentioned above. The simplest thing is tighten it up moderately. Then drill a 1/8 hole through the nut into the cover and install a 3/16 wood screw. If the cover still rattles take a small amount of grease and coat the edges of the metal backing plate and Chase the inside of outer lip of the black plastic cover with a small amount of clear silicone. Install and let cure. Done deal! |
