It is currently Sun Jul 13, 2025 11:05 pm
Reply to topic  [ 5 posts ]
 Side imaging on a mudboat?
Post Side imaging on a mudboat?
Any of you running it? I'm bout to pull the trigger on si/di for my rig, I am a lil worried about knocking the transducer off tho. Post up some pics of how you mounted your transducers.
Fri Feb 24, 2012 4:30 pm
Post Re: Side imaging on a mudboat?
Hope this helps! viewtopic.php?t=24650
Fri Feb 24, 2012 4:51 pm
I'm not sure what your particular transducer looks like. Most of them will flip up when you hit something. If it does flip up. I would run with it up and put it down when in use.
Fri Feb 24, 2012 4:53 pm
If you going to spend the money, go ahead and get the new hummingbird with 360* side imaging stick...just announced on Tuesday.
http://www.humminbird.com/360Imaging/
Looks good for a mud boat the way it is mounted. Check it out, this is going on the wish list...
Fri Feb 24, 2012 6:23 pm
P.M. Netman, he uses a side imager on his boat and has done alot of research. I'm sure he would be glad to help out.
Fri Mar 02, 2012 4:40 pm
Users browsing this forum: No registered users and 90 guests
