Should mud motors be mounted to a jackplate? http://mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=27963 |
Author: | surfbum [ Mon Mar 26, 2012 8:34 pm ] |
Post subject: | Should mud motors be mounted to a jackplate? |
I found a used mb23 mini for my 1448 allweld mod-v. Problem is its a short shaft and my boat is a tall transom. Could I mount the motor to the jack plate I have for my outboard to get it lowered or is that a bad idea? What dose it cost to turn a short transom motor to a tall? Is this a good motor for my boat? |
Author: | Puddle jumper [ Mon Mar 26, 2012 8:49 pm ] |
Post subject: | Re: Should mud motors be mounted to a jackplate? |
If your on a budget its much cheaper to cut the transom down, if you do that it might be hard to sell. Personaly I like having the tall sides and getting the motor down. I run really tight waters with alot of down trees to get under, others like to have the engine as far as possible from the water and like the tall transom. |
Author: | 23ltswamper [ Mon Mar 26, 2012 9:22 pm ] |
cut the transom if you plan on selling sell as a package if not add a full size pod with a transom on the back at the height you need this would serve a lot of purpose such as gettin in the boat and dog ramp and extra flotation should help you under a load then find a hot rod shop or some one who can weld aluminum and have them build it for you.....do a pressure check on it to make sure it is water tight. then fill it with spray foam from home depo or put a pipe nipple and valve and fill it with air...my 1448 is a 19 inch transom i have ran both sizes and they work great on long tails i also run a 15hp mercury and it is short it does cavatate on hard turns and under load takes a bit to plane out...if im bymyself shes all i need try a jack plate and lower it in save some bucks it might work if not pm me on the motor ill buy it from you lol |
Author: | eljefe [ Tue Mar 27, 2012 5:59 am ] |
You gotta allow for the motor to kick up.......when I add my huntdeck im gonna experiment with a split mount to allow motor to kick up and have room for the hydrolic trim. |
Author: | JIMMY W [ Tue Mar 27, 2012 9:02 am ] |
Seems like it would be the shit to have it on a Hydr.Jack plate so you can move it up and down?But really don't know! |
