It is currently Sat Jul 12, 2025 10:10 am
Reply to topic  [ 15 posts ]
 mud motors and salt water
Post mud motors and salt water
I'm looking at buying a used 23 mini surface drive. I'm in salt water a lot. Do i need the one that is specifically for salt water? I guess the ones for salt are galvanized.
Fri Apr 20, 2012 6:34 am
It's probably worth the money to go with that one but if you don't keep it washed and you should be ok.
Fri Apr 20, 2012 6:37 am
Post Re: mud motors and salt water
Fresh water after running is salt and some corrosionX (Red can) for spot treatment and you are good to go.
Fri Apr 20, 2012 7:06 am
MMT Moderator
Also, wrap your plug wires with electrical tape this will prevent future issues of the motor possibly grounding out because of salt spray that may come in contact with the plug wires.
GTB 1860 w/ 2019 GTR40XD-HO
Fri Apr 20, 2012 7:10 am
X2 WEA that happened to us on the way to the blind one morning
Fri Apr 20, 2012 7:50 am
I just ordered a 23 and was wondering the same thing for when i go floundering at the coast. I use corrosion x even on my outboard and figured that would be the ticket. That's stuff is awesome. Good tip about the plug wires. That's the kind of thing I was curious about and I wouldnt know to do.
Sun Apr 22, 2012 5:58 pm
I use old motor oil and soak the whole thing
Sun Apr 22, 2012 6:03 pm
But you DIDN'T wrap ya spark plug wires...
Sun Apr 22, 2012 7:12 pm
Yes I did. It was my main postive tht ran to the starter and the insulation wore off and it was touching the frame.
Dic
I put dielectric grease in my spark plug boot wrap with electrical tape and the PVC glue over tape
Sun Apr 22, 2012 7:15 pm
What Ever
Mon Apr 23, 2012 6:28 am
Mon Apr 23, 2012 11:02 am
i sprayed mine with Corrosion-X during hunting season. it works well but suck when working on your engine you get that cooked on gel all over you. but besides that it makes the engine look twice as old as it actually is. but no corrosion!
Mon Apr 23, 2012 11:23 am
I just sprayed corrosion x HD on mine, to thick I thought, but it worked but stunk the first hour or two, and is nasty to touch.
23gtr crossover Mikuni
Mon Apr 23, 2012 5:25 pm
I use a product called Salt-Away. Most of my stuff is in the salt water a good chunk of the time and this stuff does a great job of neutralizing salt issues; from corrosion issues on guns, scuba equipment, aluminum boats, and trailer brakes/lights. The stuff works pretty good. I'm hoping to have a surface drive in the next couple months and will use the stuff on it as well.
Mon Apr 23, 2012 8:28 pm
MMT Moderator
Salt away works good isn't that the same stuff they have to flush the water pumps on outboards? I'm almost positive we use that brand for our Yamaha 250
Mon Apr 23, 2012 11:25 pm
Users browsing this forum: Google [Bot] and 71 guests
