| looking for part number http://mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=2914 |
| Author: | basinlover [ Wed Jul 01, 2009 8:25 am ] |
| Post subject: | looking for part number |
Anybody know the part number for the add on oil cooler for the stage 3 motors from EVT, Mike told me they got it at oreilly,autozone etc. but didn't have the part number with him. Was going to add for the weekend. Thanks |
| Author: | coastal [ Wed Jul 01, 2009 8:37 am ] |
| Post subject: | Re: looking for part number |
CoonDick has the part number.PM him. |
| Author: | basinlover [ Wed Jul 01, 2009 8:45 am ] |
Thanks |
| Author: | J Wales [ Wed Jul 01, 2009 9:10 am ] |
Here's another one that Robert Silk told me about...its about $30 more expensive, but it's built tougher (it's built just like the stock oil cooler on the briggs). http://www.jegs.com/i/TCI/890/824101/10002/-1 |
| Author: | Mitschke [ Thu Jul 02, 2009 12:39 pm ] |
You can get Hayden oil coolers at any Oreillys. Have them look them up in the books if they dont have the size you want in stock. |
| Author: | coondik [ Thu Jul 02, 2009 12:50 pm ] |
Napa 1-4818 Attn: All Powerful Moderators sticky dis thread, please |
| Author: | River [ Thu Jul 02, 2009 1:08 pm ] |
| Author: | coondik [ Thu Jul 02, 2009 1:12 pm ] |
| Author: | SmokeEater829 [ Thu Jul 02, 2009 6:02 pm ] |
Can anyone running either of these oil coolers post some pics. I just order one, and would like to see how ya'll are mounting the coolers. Thanks! |
| Author: | deltaduckmaster [ Thu Jul 02, 2009 6:07 pm ] |
| Author: | SmokeEater829 [ Thu Jul 02, 2009 8:03 pm ] |
Thanks. Gonna try to get it installed soon. Hopefully I can figure out a way to mount it. |
| Author: | coondik [ Thu Jul 02, 2009 10:57 pm ] |
Smoke if u got de Napa one it's comes as a kit. All dat stuff is included |
| Author: | dead animal [ Fri Jul 03, 2009 8:47 pm ] |
damn terry, dat's a clean lookin setup. |
| Author: | stumpgrinder [ Fri Jul 03, 2009 9:01 pm ] |
I catch enough hell with da lil' bitty oil lines goin to da factory cooler.... I can see myself rippin dat shit apart and coverin a cypress tree with oil da 1st trip out. lol |
| Author: | coondik [ Fri Jul 03, 2009 9:10 pm ] |
Ders a differance Stumpy, u actually do work wit u'r unit! |
| Author: | coondik [ Mon Apr 26, 2010 1:23 pm ] |
her ya go bunny! now quit stalkin me |
| Author: | brlcla [ Mon Apr 26, 2010 4:47 pm ] |
most of us run a hayden #401... which is a fin/tube.... if you don't mind spending a few extra $$$ go with a hayden #676... which is a fin/plate.... The fin plate will give you more cooling due to the design.... such as the stock engine cooler.... Briggs gets away with such a small stock cooler due to the effciency of the design.... you will see that the fin/tube cooler we run a little longer and probably only cool as much as the stocker if not slightly less.... put it in series with you stock one and the motor will be happier. I would show you mine but my boat is over at EVT and its an airboat so it won't help ya much on where to put it.... but I have mine on the engine stand below the motor in the flow of the prop. |
| Author: | woffman [ Mon Apr 26, 2010 5:22 pm ] |
If anybody is interested in a stock oil cooler, I have an extra one laying around. Brand new, never installed. Let me know and I'll make you a deal! |
| Author: | Brinkleydog [ Tue Apr 27, 2010 10:23 am ] |
| Author: | brlcla [ Tue Apr 27, 2010 4:23 pm ] |
I have a fin/tube with 3/8" tubes (probably 1/2" OD) Hayden #401... and a plate/fin will outperform due to it spreads the oil over the area of the plate which radiates heat over a larger area for cooling vs just flowing through tubes and letting the fins draw the heat away... I promise you the stock cooler (plate/fin) is cooling about the same compared to the hayden's with 3/8" (1/2" OD) finned tubes... and doing it in a smaller package.... putting the stock in series with the hayden is the best route on motors than are ran hard. And my airflow across the coil is let me do the math... finned area ( 5"x8.75") air speed 40mph approx..... That comes out to about 17 cfs... and I would figure oil flow rate to be what the gear pump in the engine is rated for less minor losses in the passages and filter.... anything else ya wanna know? |
| Author: | Brinkleydog [ Tue Apr 27, 2010 6:28 pm ] |
lol...watever dude.... ill get the CFM and GPM so i can calculate it myself..... FYi..coils are always measured by the OD of the tubing inside the fins....the reason u say it is only doing as good is because it does not have the proper find per inch which does not transfer the heat fast enough for the motor..... get you a temp gauge and let me know the differance..pm me your address i got somthin that will chage your mind.... |
| Author: | brlcla [ Tue Apr 27, 2010 6:51 pm ] |
it really doesn't matter to me... its not like i put it in a program at work or anything or have the time during the day to actually do the calcs.... i got other sh*t to engineer and design..... wasnt trying to make a bid deal out of it.... i just know that plate and fins tend to be more efficient... i was not saying what i have is not working... i think the set up i have will actually do a lot better than what yall are limited to on your mud motors.... my hayden cooler is actually in my prop flow so I know I am getting much much more cooler air than what the flywheel fans are pulling through them on the motor. in all actuallity i probably have about a 45-50 mph wind blowing through my coils when i am on the throttle |
