It is currently Sun Jul 13, 2025 2:05 am
Reply to topic  [ 16 posts ]
 Any Way to Get A Prodrive to Trim Up Higher?
Post Any Way to Get A Prodrive to Trim Up Higher?
Right now trimmed all the way up the prop isn't even out of the water at all.
Is there anything I can do or adjust to get it to trim up higher. I have a 2012 with hydraulic power trim.
Thanks
Thu May 24, 2012 10:17 am
Post Re: Any Way to Get A Prodrive to Trim Up Higher?
Why does the prop need to come out of the water?
Thu May 24, 2012 10:28 am
To clear logs and other things that may not be under the surface.
What boat is your motor on?
Thu May 24, 2012 10:31 am
I don't know if mine trims that high or not. With the winch it would, I don't think it does with the hydro though. I just lift mine up to clear stuff like that. Or lock it up with the loop if I'm pushing the boat.
Thu May 24, 2012 10:40 am
Call em and get a larger roller. I got it fer $20.
Thu May 24, 2012 10:49 am
But you can't lift it up out of the water if it won't trim that high. I was just thinking he might have it on a boat with a higher degree transom angle.
Thu May 24, 2012 10:51 am
Post Re: Re: Any Way to Get A Prodrive to Trim Up Higher?
Thu May 24, 2012 11:02 am
Yea that's the main reason I was asking is because where I fish there is a ton of standing timber, logs, stumps, and everything, so I'm wanting it to trim up to clear all that stuff.
I have the motor on a 1650 Xpress. It is the hyperlift hull, so no it's not a mud hull. I was thinking it is the transom angle as well.
I just didn't know if there was maybe something simple I was over looking that I could adjust to make it trim up higher instead of as low as it goes now, because it will go lower than I will ever need.
Also I don't think you can lift it any higher than the trim goes.
Thu May 24, 2012 11:56 am
Shim it then.
Thu May 24, 2012 12:07 pm
Check the transom angle
You can get an extra 4" of clearance at the skeg by pushing down on the handle.
Thu May 24, 2012 12:08 pm
You can shim the motor if the transom angle is off that far. I don't know what size shim to use though. Figure out what the transom angle is on your boat and give pd a call. They'll get you hooked up.
Thu May 24, 2012 12:09 pm
I had thought about shims. Thanks guys. I'll check the transom angle in a few. What should the transom angle be?
Thu May 24, 2012 12:11 pm
I think its 16, man.
Thu May 24, 2012 12:16 pm
You can always get your buddies to sit on the very front of the boat. :o
Thu May 24, 2012 5:25 pm
Is it just that the boat drafts really deep in the back and it sits low?
How much freeboard you gots?
Thu May 24, 2012 7:55 pm
With the hydro-trim your motor should trim up to around 14" above the bottom of the hull when using a straight edge along the bottom of the hull and measuring to the center of the prop. You will get about another 2" when physically tilting the motor by hand before topping out. Measurement were taken on a tall transom Geaux hull.
Tue May 29, 2012 6:37 am
Users browsing this forum: No registered users and 87 guests
