spot light/ AC adapter ?
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=30460
Author:  MarshMan985 [ Mon Jul 02, 2012 4:17 pm ]
Post subject:  spot light/ AC adapter ?
First of all does anyone know of anybody that works on spotlights?
Second can anyone give me some info on installing an AC adapter in my boat. I was wondering if that draws much fire from the battery or if I should have it on a seperate battery or what? any thoughts???
Author:  msm8281 [ Mon Jul 02, 2012 7:42 pm ]
Post subject:  Re: spot light/ AC adapter ?
Do you mean DC? You will not get AC power out of a 12V DC battery unless you use an inverter.
Author:  MarshMan985 [ Mon Jul 02, 2012 8:18 pm ]
well I just need it so I can plug in a spot light so.....
Author:  marsh maniac [ Mon Jul 02, 2012 8:21 pm ]
you don't need an adapter, inverter, or anything else to run a spotlight off of a 12 volt battery. just wire it straight to the battery.
Author:  CJB [ Mon Jul 02, 2012 8:37 pm ]
Or you can just get a rechargeable spotlight and not worry about wires and plugs and clips and shit, if the spotlight you're talking about is handheld...
Author:  msm8281 [ Tue Jul 03, 2012 6:09 am ]
Author:  NFW [ Tue Jul 03, 2012 11:54 am ]
go get the adapter form wal-mart that just clips to a battery. easy simple and can move it to anywhere in the boat.
Author:  MarshMan985 [ Tue Jul 03, 2012 4:56 pm ]
I got the clips to go straight to the battery I want the AC adapter so that I can run 2 all night. Wouldnt need the adapter if they still sold good spotlights-had a brinkman LED that would last all night til I dropped it in water. :evil: Does anyone know how much fire does it charge from the battery if I'd use the adapter while having the other spotlight connected to the battery? Am I better off running the AC plug to an extra battery? Ideas are appreciated
Author:  indawoods [ Tue Jul 03, 2012 10:24 pm ]
Author:  MarshMan985 [ Thu Jul 05, 2012 10:11 am ]
look I'm really not sure what I need I know that I bought a spotlight that u can plug in a vehicle and use. And I already have a spotlight that runs to my battery so I want to hook up this one to an outlet in my boat.
Author:  P&R_Productions [ Thu Jul 05, 2012 12:37 pm ]
X2 on the picture thing, i feel like your confusing alot of ppl on here... do you have a generator in your boat?
Author:  MarshMan985 [ Thu Jul 05, 2012 3:53 pm ]
OK, I'll restart. I currently have a handheld spotlight that I bought an adapter with the clips to connect to my battery. I have another spotlight that works the same way and would like to run both at the same time. My concern was about the plug in(like u see in a car). I wanted to see if it would draw a lot of fire from the battery, make my battery life shorter, or have no affect.
Author:  Fletch [ Thu Jul 05, 2012 5:52 pm ]
Twice as fast
Author:  T-Bubba [ Thu Jul 05, 2012 6:32 pm ]
do you know the difference bt AC and DC?
you can run two lights wired 12volt DC to your battery. If your engine isnt a CDI be sure to have another battery.
I have ran two 100watt aircraft lights off my one optima yellow top while frogging with the CDI motor.
Author:  MarshMan985 [ Thu Jul 05, 2012 6:50 pm ]
Ok yea I need a 12 V DC outlet. what is this CDI? and I'm sure as long as the motor isn't on it wont draw fire so Ill probably be ok with the outlet, right?
