Prodrive Hydraulic Trim?? http://mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=32598 |
Author: | mudder [ Sat Sep 22, 2012 5:43 pm ] |
Post subject: | Prodrive Hydraulic Trim?? |
I am changing the transmission oil in hydr trim and was wondering........after emptying the bowl and reassembling, should I have the motor all the way trimmed down or up before refilling? Thanks for the input |
Author: | mudder [ Sat Sep 22, 2012 8:07 pm ] |
Post subject: | Re: Prodrive Hydraulic Trim?? |
The reason I ask is when the hdryo lines blew 2 yrs ago and I had to replace them, I was told to make sure you have the motor all the way trimmed down(i think) before you fill with trans oil. If I am just changing the oil from the resorvoir, and there is still oil in the lines, do I need to worry about whether the moror is trimmed up or down, or does it even matter? |
Author: | dualpds [ Sat Sep 22, 2012 8:09 pm ] |
It should have been trimmed all the way up before you started draining. When the rod is fully retracted it has displaced the most amount of fluid. |
Author: | mudder [ Sat Sep 22, 2012 8:30 pm ] |
got it...I didnt drain it yet so I will be able to trim it up before I start. |
Author: | dualpds [ Sat Sep 22, 2012 8:38 pm ] |
Remember not to crack any of the lines or or engine will slam down hard and fast. |
Author: | mudder [ Sat Sep 22, 2012 9:00 pm ] |
I had the original lines made to 4k PSI............pretty strong stuff!! I also have blocks and a seat cushion uner the skeg....just in case. |
