It is currently Sat Jul 12, 2025 8:02 am
[ 6 posts ] |
Prodrive Hydraulic Trim??
mudder
Joined: Sun Jan 25, 2009 11:25 am Posts: 401 Location: Wisconsin
I am changing the transmission oil in hydr trim and was wondering........after emptying the bowl and reassembling, should I have the motor all the way trimmed down or up before refilling?
Thanks for the input
_________________ Phowler Extreme 1848 with 36PDFPR
Sat Sep 22, 2012 5:43 pm |
mudder
 Re: Prodrive Hydraulic Trim??
The reason I ask is when the hdryo lines blew 2 yrs ago and I had to replace them, I was told to make sure you have the motor all the way trimmed down(i think) before you fill with trans oil.
If I am just changing the oil from the resorvoir, and there is still oil in the lines, do I need to worry about whether the moror is trimmed up or down, or does it even matter?
Sat Sep 22, 2012 8:07 pm |
dualpds
Joined: Sun Aug 19, 2012 4:06 pm Posts: 72 Location: Neenah, WI
It should have been trimmed all the way up before you started draining. When the rod is fully retracted it has displaced the most amount of fluid.
Sat Sep 22, 2012 8:09 pm |
mudder
got it...I didnt drain it yet so I will be able to trim it up before I start.
Sat Sep 22, 2012 8:30 pm |
dualpds
Remember not to crack any of the lines or or engine will slam down hard and fast.
Sat Sep 22, 2012 8:38 pm |
mudder
I had the original lines made to 4k PSI............pretty strong stuff!!
I also have blocks and a seat cushion uner the skeg....just in case.
Sat Sep 22, 2012 9:00 pm |
[ 6 posts ] |
Users browsing this forum: Majestic-12 [Bot] and 93 guests |
