It is currently Sun Jul 13, 2025 3:33 pm
Reply to topic  [ 17 posts ]
 boat driveing tips!!!!
Post boat driveing tips!!!!
So after MANY years of running LT; I had enough and bought a used brother 18x48 with a 36 PD.... So far I like the rig...
Now tonight after work I went out and played around to get a feel for how the boat handles!!! and all I can say is I NEED HELP ON HOW TO DEAL WITH SLIDEING..
I understand that once you start to slide back off the gas and turn(stop sliding) them get back on the gas??? but I an haveing a hard time doing that
Any tips would be greatfully!!!
18x48 brothers with a 36 PD passing or pulling everything in these parts
Fri Sep 21, 2012 9:37 pm
Post Re: boat driveing tips!!!!
It'll never turn like the ribbed jon boat you were prolly runnin.
All I've got to say is... Tiller time, Tiller time, Tiller time
Fri Sep 21, 2012 9:40 pm
Why don't you just back off enough to begin with not to slide like a jap Mobil drifter. Than you probably not letting off enough to stop the slide once it starts. It's pretty simple to control with a lil common sence. Get as much tiller time as possible and don't drive like NASCAR if you don't know how to control it.
Sat Sep 22, 2012 5:35 am
Or buy a round chine boat. You'll turn on a dime.
Sat Sep 22, 2012 8:20 am
Like Sammyc told me the other day.... Pretend your racing a dirt track car.. Lol
1850 & 36pd
Sat Sep 22, 2012 12:37 pm
WC CUSTOM 20X54 Battleship w/ Gator Glide Pushed & Pulled hard by an HDR!
Don't be scared...Hit It and Hold It!!!
Sat Sep 22, 2012 12:53 pm
after this morning, i seriously considered welding a few ribs to the bottom of mine
we hunt a lake that right now has about 4 inches of water on it and 4 to 6 inches of mud below it then it gets solid. So you have to run from the channels to your teal blind, in the teal blind we have a ditch that we made from going forward and backward thru the blind chute so we can take off on step when we leave the blind. so you pretty much have to drive it like you stole it most of the time during teal season.
if you slow down too much to turn, you have issues getting back on step, and it turns better when trimmed down but i have to run it trimmed high due to the hard bottom so at this point i just figure how much area an 18 wheeler would need to use to turn around, multiply it x 2 and plan way ahead.
gtr35 gt 1854 / w gatorglide
12 ft 11hp longtail
14 ft 10 hp longtail
Merc 225hp TR20
Sat Sep 22, 2012 1:12 pm
I love the way a Brother boat looks but I don't want a boat that slides and have no interest in learning how to drive a sliding boat. Good luck man. Hopefully with more tiller time you will get the hang of it.
1850 & 36pd
Sat Sep 22, 2012 1:34 pm
So I played around in deep water today...LOL main channel of mississippi...
and got the old AIR boat "hop skoch" slide and beign able to corner around the green and red cans while keeping them within 10 ft....
time on the stick helps.... and the more the better...
P.S. I used up 15 gals. of gas today...to tell you how much I want to learn this boat/style of hull.
Add that was over 2 days
Sat Sep 22, 2012 9:17 pm
15 gallons for me is basically WFO all day long. WOW.....
Sat Sep 22, 2012 10:28 pm
Yes more time on the stick always helps. And don't be afraid to go places you don't think you can go you will learn a lot like that, and even surprise yourself sometimes.
1646HD GTB and a 35GTR w/ with Calens stage 1
Sun Sep 23, 2012 9:14 am
Just slow down in turns. Its not very complicated. Thats why I like a square chine boat because you can run on step going slow and it will turn fine. Ive never understood why someone needs a duck boat that can make a 90 degree turn going 30mph.
1848 Prodigy
35 GTR
Sun Sep 23, 2012 10:45 am
My boat only runs 20 WFO and most times I find myself crusing along at 14-15mph just barely on step
Sun Sep 23, 2012 7:29 pm
x2
Sun Sep 23, 2012 9:30 pm
first off thanks too thoughs who responed!!!!!!!!!!!!!!!!!!!!
Now here is were I need help cause I mush be doing something wrong??? or is it what it is???
I can corner 5:10 perfect in deep water/ get into a slide and keep it/ get out of a slide by getting the leading side to dig...
But in shallow/skinny water 6" or less I have issues that I cann't get the boat to corner with out a ton of slideing. I back off to idle and crank on the handle but keep sliding (this is done at just enough gas to stay on step). I must be doing something wrong?? or am I going about it right and just need more stick time???
Thanks ahead of time!! also this is my FIRST square chine boat...
Mon Sep 24, 2012 8:01 pm
mine is the same way for sure, worst for the sliding is when in about 2 to 6 inches of water, will turn in deep water and also in mud, seems better tho if you put more weight to the back so when you slow down in shallow water it will dig or drop in the water slightly.
12 ft 11hp longtail
Merc 225hp TR20
Mon Sep 24, 2012 8:36 pm
It slides in shallow water because of lift/ it can't dig.
They all do it, Round, Square, Taper, Extreme...
Mon Sep 24, 2012 8:40 pm
Users browsing this forum: No registered users and 118 guests
