Siezed up horizontal swivel plate bolt.
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=33631
Author:  buckfever [ Wed Oct 24, 2012 1:30 pm ]
Post subject:  Siezed up horizontal swivel plate bolt.
This is on a 05 Mud Buddy hyperdrive. The long bolt that holds the motor horizontally to the swivel plate is moving when I turn the motor. The grease fitting will not allow any grease in. I think the previous owner didn't grease ths thing at all. It looks like to me that the bolt shouldn't be moving at all when I turn the motor left and right. The swivel plate should move around the bolt without the bolt moving left and right correct ? I have sprayed it with a good bit of PB blaster and tried to break the bolt loose with a cheater bar and a section of pipe with no luck. I got the bottom nut off fine and left it at the end of the threads and tired to tap it with a hammer with no luck. Any tips to get this thing broke free ?
Author:  mississippiduckboy [ Wed Oct 24, 2012 1:33 pm ]
Post subject:  Re: Siezed up horizontal swivel plate bolt.
Take motor off the frame and and all try changing grease nipples and putting a new one on.
Author:  autogateman [ Wed Oct 24, 2012 2:17 pm ]
Look at it close, mine is about that same year model and the 'bolt' is actually welded in place at the top. It should spin with the motor.
Author:  Robn1020 [ Wed Oct 24, 2012 4:16 pm ]
Author:  papaw [ Wed Oct 24, 2012 6:04 pm ]
it is welded to the bottom of the motor plate. there is no bearing in it .it and the nut will turn ,as the motor turns.if u take the nut off u can pick the motor and all straight up and it will come out leaving the mounting bracket and trim on the boat .watch the trim wires .
Author:  buckfever [ Wed Oct 24, 2012 8:23 pm ]
Thanks allot. So the bolt and nut should be turning with the motor ?
Author:  autogateman [ Wed Oct 24, 2012 8:41 pm ]
yes
