Just got a mud motor got a question
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=33990
Author:  mattbmud [ Sun Nov 04, 2012 6:49 pm ]
Post subject:  Just got a mud motor got a question
how do i stop water from rushing against the lower unit part of the motor and arcing up and into the boat? . i have a 20 inch transom now with one for a long transom. and the bottom of the gear box pushes water
Author:  mattbmud [ Sun Nov 04, 2012 6:56 pm ]
Post subject:  Re: Just got a mud motor got a question
hope thats easy to understand. i dont know how else to word it
Author:  mizzippi jb [ Sun Nov 04, 2012 7:03 pm ]
Sounds like you have a short transom boat and a motor set up for a tall transom.
Author:  Woodiebuster [ Sun Nov 04, 2012 7:09 pm ]
Have you played with separate trim settings?
Is the boat plaining out?
Are there bad hooks in the hull?
Author:  mattbmud [ Sun Nov 04, 2012 7:12 pm ]
i checked it 2day and it measures almost 20 inches and the guys at the dealer said its the correct motor. has anyone ever used a jack plate with a mud motor? then i could mess around with the motor height
Author:  mizzippi jb [ Sun Nov 04, 2012 7:15 pm ]
What kind of boat, what kind of motor?
Author:  mattbmud [ Sun Nov 04, 2012 7:20 pm ]
its a tracker grizzly all weld 1448 and a 23 hd sport and i got pods welded on. it just dosent seem right . most people with this set up are geting in the 20 mph im getting like ten. and i get the water rushing up into the boat when im not at full rpm
Author:  mizzippi jb [ Sun Nov 04, 2012 7:35 pm ]
I would say the pods are a lot of your problem. Your boat isn't ideal but its not causing the water hitting the transom issue.
Author:  mattbmud [ Sun Nov 04, 2012 7:44 pm ]
it did that water thing before the pods to. the pods just level the boat out a bit since the motor is so heavy
Author:  mattbmud [ Sun Nov 04, 2012 7:48 pm ]
i just gotta find some body who knows about mud motors in person and have them drive it. suck tho bc the dealers like 3 hours away
Author:  mizzippi jb [ Sun Nov 04, 2012 7:52 pm ]
I used to have a grizzly 15-42 with a 23 on it and it did pretty good.
Author:  mattbmud [ Sun Nov 04, 2012 8:04 pm ]
can the boat just be to small? would a 15 make a differnce instead of a 14. im just pist lol i was so excited to get it and watching videos of mud motors and now it sucks lol.
Author:  Quackkillz [ Sun Nov 04, 2012 8:12 pm ]
I may be wrong but it seems to me that the pods are creating a narrower channel for the water to come into, making it go in the boat, I'm no expert either, that's just what I'm picturing.
Author:  mattbmud [ Sun Nov 04, 2012 8:16 pm ]
ill take some pictures tomarrow when i go out if that will help out . thanks for everyones input so far
Author:  nasty [ Sun Nov 04, 2012 8:25 pm ]
Does the transom height measure 20" or from the top of the transom to the bottom of the boat measure 20" if it's the latter, you've got a short transom with a tall transom motor.
Author:  Will [ Mon Nov 05, 2012 5:01 am ]
Take a picture from the bottom, sounds like the gear box as you call it is acting like a board hitting the water giving the reason some think you have a tall transom motor on a not tall enough transom hull.
Author:  Swamp Star [ Mon Nov 05, 2012 2:18 pm ]
