Trim won't go down! http://mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=36718 |
Author: | Quack Stackin [ Tue Jan 22, 2013 4:53 pm ] |
Post subject: | Trim won't go down! |
2011 mb 35 sd trim will go up but don't go down, I can hear a click by the trim when I hit the switch but does nothing until I press up it goes up like normal? Any reasoning? |
Author: | dguidry [ Tue Jan 22, 2013 4:58 pm ] |
Post subject: | Re: Trim won't go down! |
Author: | dfou [ Tue Jan 22, 2013 4:59 pm ] |
Trim relay. They're under the cover by the transom clamp. Any mercury dealer had them |
Author: | JIMMY W [ Tue Jan 22, 2013 6:13 pm ] |
mudbuddy breaking.jpg Just watch it don't go down too far ![]() |
Author: | TX Aggie '06 [ Tue Jan 22, 2013 6:32 pm ] |
Author: | Quack Stackin [ Tue Jan 22, 2013 7:38 pm ] |
Yeah this is ther fourth set I've gone through but usually it all goes out together not just one, and I've had warranty up tell now so now I'm trying to fix thanks for the replys |
Author: | txmudcutter [ Tue Jan 22, 2013 8:11 pm ] |
Put some dielectric gel under those caps to help keep some of the water out of them |
Author: | TX Aggie '06 [ Tue Jan 22, 2013 8:14 pm ] |
Author: | HH_Kennels [ Tue Jan 22, 2013 8:31 pm ] |
Author: | dguidry [ Tue Jan 22, 2013 8:34 pm ] |
Author: | MONDAGO [ Tue Jan 22, 2013 8:38 pm ] |
Neither will my wife, I just deal with it.... ![]() |
Author: | barnes_53 [ Tue Jan 22, 2013 8:56 pm ] |
You can reverse the polarity on the switch. One of the things the Gator Trax crew educated me on when I got my MB in case this happened in the field. |
Author: | bayouboy [ Mon Jan 28, 2013 12:08 pm ] |
http://www.ebay.com/itm/Universal-250A- ... f4&vxp=mtr I've been through just about every type of relay and high amperage switch out there between GT and PD. This reversing solenoid replaces the relays and also takes the high load off the switches. O-ring seal and 250 amps! I've been installing them for almost a year now with no issues or problems what so ever. And the nice thing about it is that you can add as many remote switches that you want, be it the tiller, your seat , where ever. The only down fall is the switch that comes with it is not H2o proof so you have to use the one on your motor or buy a H2o proof one. Thanks for listening. |
Author: | Quack Stackin [ Mon Jan 28, 2013 12:52 pm ] |
best place to get new relay from? |
Author: | Quack Stackin [ Mon Jan 28, 2013 12:56 pm ] |
and if anyone has the part# it would be appreciated, switchin them works for now but its almost time to start bowfishing and need it to go both ways |
Author: | MALLARDSX2 [ Mon Jan 28, 2013 2:30 pm ] |
I pack my relays with grease |
