Mack
Joined: Wed Jul 15, 2009 7:52 pm Posts: 233 Location: SW Jawja
 recs on motor with reverse
Alright, I'm pretty new to the mud motor stuff, but I am looking at getting a boat and a motor in the next year. I'll be using it mostly for duck hunting and fishing the flats and rivers near Enchofina and the Aucilla rivers. I would prefer to have a motor with a reverse. What are your thoughts? Recommendations? Thank you in advance.
Mack
_________________ Just throw the rubbers on the dash and take a chance
| Tue Aug 04, 2009 12:21 pm |
craig
 Re: recs on motor with reverse
Well, if you want reverse that narrows your search to the best 2 mudmotors. Gator Tail and pro-drive. One has instant reverse while the other takes a couple seconds to ratchet around. Go to each of their websites and look at the videos. Then go for a test drive. Good luck.
| Tue Aug 04, 2009 12:38 pm |
forever draggin
Joined: Tue Jan 13, 2009 7:10 pm Posts: 6664 Location: in the marsh with a boat load full of dead hookers
| Tue Aug 04, 2009 1:28 pm |
schrieverboy
Joined: Tue Jul 21, 2009 7:06 am Posts: 916 Location: South,La
the prodrive has a very good reveerse. but watch it in deeper water
_________________ 1648 w/ a 36 pd fpr on dat biatch G-14 CLASSIFIED SKIFF ON DA WAY!! Never try to educate someone who resists knowledge at all costs.
| Tue Aug 04, 2009 1:33 pm |
jpc014
Joined: Tue Mar 10, 2009 8:17 pm Posts: 785 Location: Meraux, LA
HRCH Cajun Black "VOODOO" Magic 18x48 Center Console PD w/32PDHydro T&T; Hydro Reverse "If I wanted any of your lip; I would pull down my zipper"
| Tue Aug 04, 2009 3:04 pm |
schrieverboy
i almost swamped ma boat first time with it
| Tue Aug 04, 2009 3:16 pm |
Crews
Joined: Wed Jan 14, 2009 9:07 pm Posts: 2260 Location: Lafayette
that's probably a driver error thing... let it idle in deep water, and don't give it any gas or you might take on a little water. I like my PD/FPR, and wouldn't trade it for anything. Gatortail makes a nice motor, and if you never get yourself in a bind, that instant reverse works pretty good too.
_________________ 24x60 Dual Prodrives
| Tue Aug 04, 2009 3:45 pm |
schrieverboy
it was my fault definitly..... gatortail woulda been my second choice
| Tue Aug 04, 2009 3:56 pm |
deltaduckmaster
| Tue Aug 04, 2009 6:25 pm |
schrieverboy
i think its pretty much impossible to not get yourself in a bind wit a mm... i try to put maself in binds jus to c if i can get out
| Tue Aug 04, 2009 6:31 pm |
jpc014
| Tue Aug 04, 2009 8:25 pm |
muddiejeep
Joined: Tue Jan 13, 2009 6:24 pm Posts: 761 Location: New Orleans, LA.
Idle in open water with FPR. Running WFO in open water with FPR is fine, its when you let off the throttle that you get a boat full of water.
_________________ When in doubt, throttle out. 18x60 prodrive w/36 prodrive
| Tue Aug 04, 2009 8:33 pm |
Mack
Thank you for the input guys. I figured both were great motors and both would work just fine for I want it for. I have seen some great deals on here and will continue to look as time goes on and I get closer to making my purchase.
Mack
| Wed Aug 05, 2009 6:52 am |
MaXXis85
I got the GTR and When Im hard on reverse i get water/mud in my boat too. Best best for the OP is to go test drive and demo each motor and see what he likes!
| Wed Aug 05, 2009 7:48 am |
bayouboy
Joined: Tue Jan 13, 2009 6:08 pm Posts: 5376 Location: Venice, La
I"ve run FPR wide open throttle every where, deep or shallow and I have the short shaft motor. Definitally operator error ( No offense schrieverboy) I did the same thing when I first got mine (live and learn). You just have to trim the motor all the way up to start off when in reverse and in the deep stuff, you trim down as you increase on the throttle and pick up speed. and the opposite when your slowing down, meaning trim back up when your slowing down. turning the boat 90 degrees before stopping also helps with the back splash. if possible.  I've personally have had more problems in the shallows (1 to 2 feet) with the boat wanting to catching suction to the bottom when I slow down and not wanting to pop back up! This is running FPR in 12 foot of water, 15.7 mph. LOL
| Wed Aug 05, 2009 8:20 pm |
schrieverboy
| Wed Aug 05, 2009 8:37 pm |
bayouboy
| Wed Aug 05, 2009 8:50 pm |
schrieverboy
coonass babe hard head and no ass lol
| Wed Aug 05, 2009 8:52 pm |
