Which grease seals for MM build? http://mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=36887 |
Author: | Kendall Steffensen [ Sat Jan 26, 2013 8:00 pm ] |
Post subject: | Which grease seals for MM build? |
Hi, Several posts point me towards mcmaster.com for grease seals, but there are about a dozen choices on the site. Which type of grease seals do I need to match with brass bushings? Thanks, Kendall |
Author: | Gameover [ Mon Jan 28, 2013 2:35 pm ] |
Post subject: | Re: Which grease seals for MM build? |
if it was me i would get away from lip seals all together and get you a bearing isolater (inpro). no contacting parts, reuseable, never need to replace. |
Author: | Kendall Steffensen [ Mon Jan 28, 2013 3:12 pm ] |
Thank you for the reply. Reading between the lines, are lip seals what I need to go with brass bushings? Can you point me in the direction of a bearing isolator, I would like to check out that option. Thanks again, Kendall |
Author: | OlSchool [ Mon Jan 28, 2013 7:29 pm ] |
Kendall, you cannot use bearing isolators on a mud motor. You must use a lip seals to hold water out. You need to know your shaft diameter and the bore you wish to press the seal into.http://www.timken.com/en-us/products/se ... ature.aspx |
Author: | Kendall Steffensen [ Tue Jan 29, 2013 9:02 am ] |
OlSchool, Thank you, your help is appreciated. Have a great day, Kendall |
