gt replacement trim
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=38247
Author:  sskparker [ Fri Mar 01, 2013 7:18 pm ]
Post subject:  gt replacement trim
Got the new gt replacement trim. Installed it works great. But when trim is going down it makes a squealing
noise. I backed all bolts off a little to make sure they where not to tight and it still dose it. Any ideas? Thanks
Author:  garrettpearce [ Fri Mar 01, 2013 7:23 pm ]
Post subject:  Re: gt replacement trim
It's too g to clear up
Author:  sskparker [ Fri Mar 01, 2013 7:29 pm ]
it's too g to clear up?.........did u mean it will clear up?
Author:  mizzippi jb [ Fri Mar 01, 2013 7:40 pm ]
Author:  Gameover [ Fri Mar 01, 2013 7:46 pm ]
I have the 2013 trim and it noisy but still works
Been like that since day 1
Author:  sskparker [ Fri Mar 01, 2013 7:54 pm ]
thanks, will call gt monday just so they will know. i'll run it till then trim has a one year warranty. other than noise it seems to respond better than the old style trim.
Author:  Wildberry [ Fri Mar 01, 2013 8:03 pm ]
Is the amount of trim the same on the new and old trim units ? Not that it matters was just qurious
Author:  sskparker [ Fri Mar 01, 2013 8:08 pm ]
yes it is i marked it and trims just as much. when ordering they ask if u got 23 or 35hp. the differents is the piovit block that mounts on front side of trim.
Author:  Team Camo [ Fri Mar 01, 2013 8:10 pm ]
Some squeal on way down. Just keep working it & it'll stop eventually. It's just a lil air pocket causing the squeal and will work itself out.
Author:  sskparker [ Fri Mar 01, 2013 8:18 pm ]
thanks for all the posts. i will run it a bit. and then give a update. i thought that, that it was air in it.
Author:  Team Camo [ Fri Mar 01, 2013 8:28 pm ]
8-) I might've had 1 or 2 or 3 or... :lol:
Author:  garrettpearce [ Fri Mar 01, 2013 8:36 pm ]
Yes auto type. It should clear up. Mine did when I had it
Author:  FowlMouth251 [ Fri Mar 01, 2013 8:44 pm ]
Just bought one a couple months ago and it did it at first but cleared right up!
Author:  gmccurry [ Sat Mar 02, 2013 11:22 am ]
Mine does the same.
Author:  theplayer [ Sun Mar 04, 2018 7:56 am ]
I know this is old but I got the new style GT trim unit 3-4 years ago and it squeals on trim down but not on trim up. I thought it would go away but it never did. It still squeals on trim down if it has been sitting on trim up for a while with the motor level. If I let it sit trimmed down for a while it won't squeal at all. It has to have air in the fluid. Do others still have units that squeal on trim down? Anybody know a fix like adding fluid or trying to bleed out air?
