It is currently Wed Jul 09, 2025 8:58 pm
Reply to topic  [ 25 posts ]
 Optional water trap for Go-Devils - is it worth it?
Post Optional water trap for Go-Devils - is it worth it?
It's only $55 so I'm probably going to order one with my motor here in a couple weeks regardless, but what could happen without one? Is it something that could save some wear and tear on the motor over the long run? What's it's purpose, other than the obvious?
Tue Jun 11, 2013 8:27 pm
Post Re: Optional water trap for Go-Devils - is it worth it?
Water trap on fuel system - micro filters out crap before it gets to your carb and
seperates any water that condenses in ethanol rich fuel.... I like having one !
Tue Jun 11, 2013 8:31 pm
I can't see a reason to have one. I only run a 6 gallon tank and mine never sits for any length of time. Keep an eye on your fuel filter for trash. Maybe I'm just wrong.
Save your $55 for head work and go fast!
Modded 36 PD draggin' around an 1848 PD boat backwards!
Tue Jun 11, 2013 8:43 pm
Buy it for 30 dollars and install it yourself. I have seen ethanol fuel varnish and separate in a fuel line in one week.
1648 gd hull flying in front of a stage 3 with fpr
Tue Jun 11, 2013 8:46 pm
Some people run em, I didn't have on my pro xs, I don't have on on my bay boat, or my scully so I'm damn sure ain't putting one on my mudboat
def spend the money. if u get water in your gas it will lock up your engine until u pull spark plugs to get it out. water doesnt compress
Wed Jun 12, 2013 6:26 am
Worth every penny!Wouldn't run one without it ;)
Wed Jun 12, 2013 7:00 am
40HP Gatortail
Wed Jun 12, 2013 10:01 am
is this water trap just a standard fuel water seperater?
Wed Jun 12, 2013 10:47 am
Yes
Wed Jun 12, 2013 11:36 am
I have one on all four of my boats. Yes to getting it.
18x48 GDSD boat
Wed Jun 12, 2013 11:46 am
Use it, but also make sure you change the filter.
Wed Jun 12, 2013 1:14 pm
I've always had them on my boat thinking it was needed. But I always had aluminum tanks. Hoyt Told me when I got my first boat with plastics tanks that I wouldn't need a water filter. Since then I never had one and never one problem with fuel. But I do think they don't hurt also
17x48 extreme stage 2 GTR
Wed Jun 12, 2013 1:18 pm
I have one in my boat. The way I feel its better to be safe than sry on somethin like this. I get mine from Napa they are a little cheaper than from go devil
Gen III Pro Drive with a JBP stage 2 pushin 18x54 madmancustom
Jus nut up and grab a handful of throttle
Wed Jun 12, 2013 1:37 pm
If you don't plan on using the boat a lot get it. I fill mine up 3 times a week so I don't get no old fuel
Wed Jun 12, 2013 1:45 pm
Wed Jun 12, 2013 1:49 pm
40HP Gatortail
Wed Jun 12, 2013 1:54 pm
what do yall do when water gets in gas at station and u pump that into tank.... for u guys that fill up 3 times a week the odd are probally not in your favor
Wed Jun 12, 2013 1:58 pm
Wed Jun 12, 2013 2:02 pm
17*38 Klibert 23GDLT
Wed Jun 12, 2013 2:11 pm
Wed Jun 12, 2013 2:53 pm
When I first got my boat I was having hell with it and ended up having to take it in somewhere and have them "fix" the problem. I put a water filter and changed the hose and put a shutoff valve in and I run the motor try every time and haven't had any issues since. Can't say if it was all those or one of them that fixed the issue but I will continue to use it.
Fri Jun 14, 2013 8:36 am
Fri Jun 14, 2013 10:37 am
Fri Jun 14, 2013 11:28 am
Users browsing this forum: No registered users and 110 guests
