It is currently Sat Feb 14, 2026 12:01 am
Reply to topic  [ 25 posts ]
 marine audio
Post marine audio
looking for some marine audio system ideas . i know some of you out der have dem cooler boombox's and ipod hook ups.
post up what you got
<"({{{}<< 1854 Prodigy CC
Tue Feb 03, 2009 9:51 am
Post Re: marine audio
i've had several. none of them were fancy like sum guys have. the best one i've had and seen were made in a playmate style cooler wif just a radio wif good outpoot like 50wx 50w or more wif 2 speakers on the outside.
be sure to get a radio dat is compatable wif ur ipod.
i gots a bose docking station dat i ain't figured out how to waterproof yet, cause it jams.
small but sounds good. u can run jugs, lines, or traps and it's not in da way.
the sound is better in a bigger icechest, but it is bulky.
good luck.
Tue Feb 03, 2009 10:09 am
Ice chest wit a couple o 6.5's and a cd player wit a ipod hook up
Just your basic cracka ass cracka
1840 gator tail with 35GTR
15xx Bateau with 15 honda
Tue Feb 03, 2009 12:18 pm
Boom Box with dual cassets. 16 D batteries and I am set! :D
Actually, all I have is a little crank radio in my boat.
Illowa Marine - Home of Illowa Pro-Drive and the Phowler Boat Company
Tue Feb 03, 2009 12:51 pm
I have a Jensen AM/FM CD player in a marine enclosure mounted under my center console with 2 6.5 dual marine speakers. It jams!! 8-)
1754 PD Center Console, 60 Yammy, w jack plate
Tue Feb 03, 2009 2:39 pm
Tue Feb 03, 2009 2:51 pm
http://www.fullwavemarine.com/pwcsoundsystem.html
Tue Feb 03, 2009 2:55 pm
that chick would look good in my duck boat.
WC 1848 Bateau w/ 36 PD FPR
Tue Feb 03, 2009 4:16 pm
How about one of them PVC tube style ones their running on quads?
Stuff it up under the front deck.
Tue Feb 03, 2009 4:58 pm
About to flush mount a cd player and 4 - 6.5's in the seat box i bought from swampsnyper. That was pretty much the reason I bought it.
Heres a question for yall -
Are yall running your sound systems on the cranking battery or a seperate one and how long would a seperate battery running the cd player on high volume with no amplifier last without charging?
1854 Gatortail CC . 35 GTR Stage 2
Tue Feb 03, 2009 6:48 pm
Tue Feb 03, 2009 7:25 pm
Tue Feb 03, 2009 7:29 pm
Tue Feb 03, 2009 7:33 pm
Tue Feb 03, 2009 7:38 pm
Wed Feb 04, 2009 5:16 am
I got a marine cd player with 2 6in speakers mounted in a flambou robo duck box (like a plastic tool box) with a rechargable 12v gel battery for a deer feeder in the box and it last about 8 hrs.
1948 Aucion's SS Edition Bateau with a stock 35GTR
Wed Feb 04, 2009 8:00 am
DeWALT jobsite radio that runs off 18v batteries. I WILL put my new ipod in a waterproof box this year. :o
You should see the look on the kayakers faces when I cue up "Dueling Banjos" on the river about dusky dark. Hilarity.
1660 Rhino High-Side with center console
90/65 Mercury 2 stroke Outboard jet pump
Run shallow, run loud.
Wed Feb 04, 2009 9:08 am
Wed Feb 04, 2009 9:52 am
Wed Feb 04, 2009 8:06 pm
i've got an audiotube thats what the pvc one's are called they are easy to make all you do is get (2) 6" pvc 90* and some pipe, make sure the 90* are both the one's the you put the actual pipe inside. decide how wide you want it to be and then take what pipe you have left and put it in the open end and cut off flush on both sides this way when you put your 6" speakers in the screws have something to screw into. the screw will seat itself between the 90 and pipe you cutt off flush! here are some pictures of mine.
http://i254.photobucket.com/albums/hh96 ... 2-Copy.jpg
http://i254.photobucket.com/albums/hh96/volsjp/037.jpg
http://i254.photobucket.com/albums/hh96/volsjp/031.jpg
What is THAT????? Aw Hell Ground Check IT!!!!!
Thu Feb 05, 2009 12:27 am
hey kook...wheres your avatar?
Thu Feb 05, 2009 8:55 am
Thu Feb 05, 2009 9:37 am
Get a Pelican case for your ipod. Those things hate water. Ask me how I know and why I'm rocking the metallic pink ipod these days. :cry:
Thu Feb 05, 2009 7:56 pm
how do you know about the pelican case? & why you rockin the metalic pink ipod?
Thu Feb 05, 2009 8:26 pm
Kook that is an ipod on top of xm radio. if you look on the right handle bar from the seat view then you will see the ant. and yeah the amp is inside the tube. there is a cig plug coming out of it and thats what i use. it's been completely under water so i know it works in water.
Thu Feb 05, 2009 8:58 pm
