It is currently Wed Jul 09, 2025 9:19 pm
Reply to topic  [ 34 posts ]
 Gtr won't crank
Post Gtr won't crank
Battery is good everything works but won't crank.. Circuit breaker?
18x54 GTB 35GTR "the hairy merganser II"
"Sometimes you just gotta hang your pistols up and let your hair down"
Sun Aug 11, 2013 1:01 pm
Post Re: Gtr won't crank
main fuse or ignition switch or kill switch
I gave up mud motors
Sun Aug 11, 2013 1:03 pm
Won't turn over or won't fire up?
Sun Aug 11, 2013 1:04 pm
Think the starter got salty
Sun Aug 11, 2013 1:12 pm
Nothing.. Ran jumper straight to starter got nothing
Sun Aug 11, 2013 1:16 pm
Starters usually stay good. Thought mine was going out but it ended up my battery w as going bad...
Black ops IITX marshstalker
1840 WC www.wccustomboats.com
fuel injected 25 GTR
Sun Aug 11, 2013 1:19 pm
Won't turn over at all
Sun Aug 11, 2013 1:33 pm
When you are hooking jumper cables straight to starter - big sparks and no turn = shorted starter, or stuck shaft ... no sparks and no turn = most likely stuck brushes (or badly worn).
If it is the brush situation, tap (don't wail ) the lower part of the starter where the brushes are - a lot of times it will free up the stuck brushes
It's a new optima blue top but I'm gonna do some trouble shooting with other batteries
Sun Aug 11, 2013 1:34 pm
Sun Aug 11, 2013 1:35 pm
does the gtr have a 30amp main fuse
does your trim work?
Sun Aug 11, 2013 1:36 pm
Yes and yes
Sun Aug 11, 2013 1:44 pm
if the fuse is good... jump the starter solenoid to the lead with a screw driver...
if it dont spark start tracing back from the battery
Sun Aug 11, 2013 1:46 pm
Sounds good.. Thanks for the help. Soon as this torrential downpour stops its time to figure this thing out
Sun Aug 11, 2013 2:00 pm
Make sure clutch is not engaged.....if it is and you try and start it you will get nothing......
Sun Aug 11, 2013 2:04 pm
HOTSAUCE170 wrote:
Sun Aug 11, 2013 2:05 pm
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Sun Aug 11, 2013 2:33 pm
Mine will start with the clutch switch engaged
Sun Aug 11, 2013 2:40 pm
Somebody's been playin with your wiring then, cause it aint supposed to
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Sun Aug 11, 2013 2:43 pm
Yea I know. I tested it out to see if it would and sure enough it fired up. Brought back the old go devil days
Sun Aug 11, 2013 2:53 pm
Yeah it ain't the clutch.. I thought through all the dumb stuff before posting trust me lol.. Everything works but no crank. Clutch engages trims fine.. Just waiting on rain...
Sun Aug 11, 2013 3:02 pm
The starter relies on the solenoid to engages the bendix and transfers power to a set of contactors to power the starter's motor. If the solenoid is froze up nothing will happen but sparks, but IF the solenoid is working and the starter is froze you should hear the distinct click/ actuation of the solenoid engaging the bendix / power contactors then sparks.
Also, are your battery leads getting hot?
Sun Aug 11, 2013 3:15 pm
I am getting no noise at all when turning the key. It looks like somehow saltwater corroded around the screws pretty good on the starter. Haven't noticed the wires getting hot.
Sun Aug 11, 2013 3:39 pm
does the clutch engage?
Sun Aug 11, 2013 3:41 pm
open handle look for broke wire
- Mark Twain
Sun Aug 11, 2013 3:42 pm
Yep clutch engages fine. Just waiting on the weather.
Sun Aug 11, 2013 3:54 pm
Check ground wire on starter
Sun Aug 11, 2013 4:50 pm
Held the yellow wire to the starter.. Loose connection.. Damn lol
Sun Aug 11, 2013 5:13 pm
^^^ big dummy :lol: :lol: :lol: :lol:
- Mark Twain
Sun Aug 11, 2013 5:23 pm
Lmao!!!! At least it was an easy fix
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Sun Aug 11, 2013 5:24 pm
As soon as I open my mouth about "checking the dumb stuff" lol.. It's that team camo sticker adding HP.. My little stock GTR can't take the heat!
Sun Aug 11, 2013 5:40 pm
Sun Aug 11, 2013 5:52 pm
:lol::lol::lol::lol::lol:
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Sun Aug 11, 2013 5:53 pm
Sun Aug 11, 2013 8:50 pm
Users browsing this forum: Google [Bot] and 85 guests
