Where to get fuel line
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=44539
Author:  berretax35 [ Thu Aug 22, 2013 1:32 pm ]
Post subject:  Where to get fuel line
Planning to move my fuel tank up front. Have seen some picture with boats that have a blue line running up to motor is that the fuel line? Either way, where are yal getting your 20ft of fuel hose at? Local autoparts? Thanks
Author:  Louisianaboy [ Thu Aug 22, 2013 2:02 pm ]
Post subject:  Re: Where to get fuel line
Autozone. Advanced auto parts. Mostly all auto stores have fuel line
Author:  War Eagle 1 [ Thu Aug 22, 2013 2:09 pm ]
Looking to replace mine also. That stuff is expensive. What size y'all running?
Author:  berretax35 [ Thu Aug 22, 2013 2:23 pm ]
When I tried to search before I posted everyone said 1/4 or 5/16. I'll just do whatever my factory hose is war eagle
Author:  Louisianaboy [ Thu Aug 22, 2013 3:46 pm ]
I'm running 1/4
Author:  Bigbuckfever [ Thu Aug 22, 2013 3:51 pm ]
5/16. I just measured the fittings and matched it
Author:  MNGunner [ Thu Aug 22, 2013 4:13 pm ]
http://www.defender.com/product3.jsp?pa ... id=1404042
Author:  Bigbuckfever [ Thu Aug 22, 2013 4:21 pm ]
Ooh yeah, i just got mine at the local hardware store
Author:  270Handiman [ Thu Aug 22, 2013 4:28 pm ]
Boatdr sells ethanol resistant fuel line pretty cheap. I think he buys it in 1000' rolls.
Author:  berretax35 [ Thu Aug 22, 2013 5:11 pm ]
Thanks buck fever I'll just check the part store when I get home, just trying to decide if I need to go ahead and order it offline if I need to
Author:  missile [ Thu Aug 22, 2013 8:45 pm ]
I will say this about fuel line size it might start an argument but here it is. Boat came to me with stage two motor guy had to add an electric fuel pump then he started having problems again with it. He was running 3/8 line so I switched it all out to 1/4 and did away with the electric pump and just ran the stock pump motors running great and hasn't had anymore issues. Makes me think something with the stock fuel pump need to pull presure instead of volume. I would go with the eathonal line especially if you boat sets up a lot. If you run it a lot reguler fuel line is fine.
Author:  Buzz Killington [ Thu Aug 22, 2013 9:03 pm ]
West Marine
KCCO
Author:  msm8281 [ Thu Aug 22, 2013 9:05 pm ]
Any local marine store or outboard shop. Just bring plenty of money. It's not cheap.
Author:  JLACOUR [ Thu Aug 22, 2013 9:10 pm ]
Author:  USCG4X4 [ Thu Aug 22, 2013 9:13 pm ]
Got mine at advanced. Just had them cut it off the spool. I'm running 1/4 in line and I always use stabil marine ( ethanol treatment ) everything I fill up. Ethanol treatment and stabilizer in one.
Author:  T-Bubba [ Fri Aug 23, 2013 5:31 am ]
get the blue or grey 1/4" ethanol line
Author:  mud slinger 69 [ Fri Aug 23, 2013 5:57 am ]
Napa is were i get it. I run 1/4in.
Author:  msm8281 [ Fri Aug 23, 2013 6:00 am ]
Get the blue. I had trouble with the liner separating on the grey.
Just my experience
Author:  War Eagle 1 [ Fri Aug 23, 2013 7:18 am ]
So 1/4" should do, where around Lafayette could I find it? Went to a couple auto parts places but all they had was some black hose. West marine has some also but not the blue.
Author:  msm8281 [ Fri Aug 23, 2013 8:04 am ]
Author:  USCG4X4 [ Fri Aug 23, 2013 8:12 am ]
I use the black stuff and don't have any problem. I use ethanol treatment so it doesn't get in the lines to do damage.
Author:  berretax35 [ Fri Aug 23, 2013 12:37 pm ]
Author:  jc [ Fri Aug 23, 2013 7:09 pm ]
Black automotive is good. Actually I think its better than the marine line. How many cars and trucks do you see having problems with their fuel lines. I know yall going to say they don't sit like a boat, but I have a truck that will sit 8 months at a time and no problems. Had marine fuel line go bad in 2 years.
Author:  War Eagle 1 [ Mon Aug 26, 2013 12:24 pm ]
I got the blue ethanol "PROOF" fuel line at mikes marine in broussard la. It was cheaper than all the automotive places. 2 dollars and something cents per foot as O'reilly wanted 5 something a foot.
Author:  berretax35 [ Mon Aug 26, 2013 8:38 pm ]
Sheyat I have an oriellys just up the road that's unfortunate. May just order mine from Mike then. Or call around north Al
Author:  berretax35 [ Mon Aug 26, 2013 9:50 pm ]
If I could ever get of this gahl dern towboat I'd be able to see myself. Wednesday I'll be able to get all this sht going
Author:  War Eagle 1 [ Mon Aug 26, 2013 10:17 pm ]
