how do yall trailer your surface drives?? http://mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=45557 |
Author: | opfdfire [ Tue Sep 17, 2013 7:29 pm ] |
Post subject: | how do yall trailer your surface drives?? |
I just upgraded to a 2100 copperhead and im trying to figure out the best way to strap the motor down when the boat is on the trailer and im going down the road. I have a strap wrapped around the handle pulling the motor down into the boat and its tied on the trailer. any suggestions and pictures would be great thanks! |
Author: | North LA Hunter [ Tue Sep 17, 2013 7:33 pm ] |
Post subject: | Re: how do yall trailer your surface drives?? |
If you have a welder build you a transom saver that goes in-between the belt housing and your trailer. Then strap it from each handle on your boat to keep pressure on it. Sorry don't have any pics but a buddy of mine did it to a mud buddy. |
Author: | Bigbuckfever [ Tue Sep 17, 2013 7:39 pm ] |
Author: | North LA Hunter [ Tue Sep 17, 2013 7:41 pm ] |
Minimize bounce of motor = less stress off of transom. |
Author: | opfdfire [ Tue Sep 17, 2013 7:43 pm ] |
they way I have now the bounce is minimal and any movement is more on the pivot point than the transom. so its not that bad. Im coming from a longtail that swiveled 360 and once I strapped it down it didn't move and now this slight bounce makes me nervous. I could rig a transom saver up but I don't really have the time right now. I'd really like to see some pic of how people haul theirs if anyone has any. |
Author: | Bigbuckfever [ Tue Sep 17, 2013 8:20 pm ] |
Author: | North LA Hunter [ Tue Sep 17, 2013 8:23 pm ] |
Author: | Bigbuckfever [ Tue Sep 17, 2013 8:57 pm ] |
I should have posed my original comment as more of a question than i did. I agree with what your are saying. I suppose a standard outboard style transom saver does no more or no less than the design you propose. Sent from my DROID RAZR using Tapatalk 2 |
Author: | usfgeology [ Tue Sep 17, 2013 10:09 pm ] |
So the OP is talking about a different motor but this got me wondering. Do you GTR/GTB owners use a transom saver or just the U-bracket for eliminating side to side movement? |
Author: | North LA Hunter [ Wed Sep 18, 2013 5:42 am ] |
I just run my trailering bracket and that's all. Had a mb and never put a strap on it. But they were on boats that I build not Jon boats. |
Author: | eljefe [ Wed Sep 18, 2013 7:00 am ] |
The gtr bracket holds motor from moving side to side and up and down...... sent from the former Republic of Texas. |
Author: | JLACOUR [ Wed Sep 18, 2013 7:42 am ] |
^^ slick design fosho! |
Author: | mcquesten [ Wed Sep 18, 2013 3:02 pm ] |
My ProDrive doesn't move with nothing on it |
Author: | chasinmallards [ Sun Sep 22, 2013 5:00 pm ] |
I have an 18 HP copperhead. I usually run a strap through the little hole in the diagonal support bar that has the copperhead logo cut in it. When I picked it up from Illowa Marine, they had a wood block in between the belt housing and the transom, but i've already lost several of them on the road. So now I don't bother. The strap keeps it from bouncing and turning but a big bump will still bounce it a bit. I am still kind of looking for a better way. I don't think the motor is heavy enough to crack the transom. I guess if it does, I have a lifetime warranty on the boat from Illowa. Considering I am strapping it down their way, I think they would fix it. |
Author: | bueller [ Sun Oct 06, 2013 5:26 pm ] |
With my Copperhead I just turn the handle to the left side of the boat and run a bungee cord from right in front of the prop to the grab handle on the right side of the transom. It stays tight and doesn't bounce an inch down the road. |
Author: | waterfowl1 [ Tue Oct 08, 2013 12:40 pm ] |
trimmed all the way up and run a strap around the tail to the ass of the boat on both sides. |
Author: | deltaduckmaster [ Tue Oct 08, 2013 1:03 pm ] |
I'm sure all those horizontal mud motor makers will just copy Gatortail's way of doing things. They have copied just about everything so far!!;) |
Author: | Will [ Tue Oct 08, 2013 1:06 pm ] |
Author: | 270Handiman [ Tue Oct 08, 2013 4:15 pm ] |
The old integral MB travel lock on the hypers was a good design. |
Author: | Wildberry [ Tue Oct 08, 2013 5:34 pm ] |
Author: | Swamp Wader [ Tue Oct 08, 2013 5:34 pm ] |
Author: | tylerduckman [ Tue Oct 08, 2013 6:47 pm ] |
I haul mine on the back of a boat.. |
Author: | brasso [ Wed Oct 09, 2013 11:09 am ] |
Author: | rob_E [ Wed Oct 09, 2013 11:15 am ] |
ImageUploadedByTapatalk1381338919.598734.jpg Like this |
Author: | barnes_53 [ Wed Oct 09, 2013 11:17 am ] |
I usually just leave mine attached to the hull on the trailer. |
Author: | Woodiebuster [ Wed Oct 09, 2013 11:20 am ] |
I take the motor off and put it in the back of the truck |
Author: | Old School [ Wed Oct 09, 2013 11:22 am ] |
Some just drag the sport V behind the boat. |
Author: | brasso [ Wed Oct 09, 2013 12:40 pm ] |
