It is currently Mon Jun 23, 2025 7:17 pm
[ 5 posts ] |
New owner 35 HP VAnguard GD Surface Drive
Hellsbells
I have a 35 HP Vanguard Go Devil surface drive. It is 4 years old and new to me. I have a few questions and need some help.
The motor is mounted on a 1648 go devil boat. I can only get around 20 MPH out of it right now. The motor was in meed of some maintenance and I have completed most of it. The only 2 things left to do right now are installing a new kill switch and a new tiny tach. Neither are working.
So I do not know how many rpms I am turning. What should it turn (max) in water and out?
I did just yesterday change out the air filter which looked horrible. Could this cause a loss of rpms and speed? I have not had a chance to run it yet.
My other concern would be the prop. It has a 3 blade on it and it looks a little worn to me. It is smooth and rounded, much different from my boat props. Should the blades be edged and defined?
What is the best prop for this motor? I would appreciate any input on the above.
Thanks
Thu Sep 19, 2013 7:43 am |
postalpaul
Joined: Sun Nov 01, 2009 6:25 pm Posts: 1935 Location: Kaufman- TEXAS
 Re: New owner 35 HP VAnguard GD Surface Drive
O
Thu Sep 19, 2013 7:49 am |
odass
should turn around 4300 out of water
_________________ Dead Fowl Custom 1954hd with a GTR
Thu Sep 19, 2013 5:23 pm |
cmk07c
Joined: Thu Jul 21, 2011 9:11 am Posts: 556 Location: Metairie, LA
Even with a smoked prop I would think it would run better. You should see 30 when you get it fixed.
Thu Sep 19, 2013 7:27 pm |
Team Camo
Clogged air filter could have been killing your rpm, causing slow top speed, but a worn prop will also cause poor speeds. Really need to replace the tach to find out where rpm is at to try to diagnose speed issues. If not turning rpm = slower speeds, if turning rpm but have worn prop = slower speeds (as well as vibration & tendency to try to climb out of water).
Fri Sep 20, 2013 7:06 am |
[ 5 posts ] |
Users browsing this forum: No registered users and 419 guests |
