I have a 35 HP Vanguard Go Devil surface drive. It is 4 years old and new to me. I have a few questions and need some help.
The motor is mounted on a 1648 go devil boat. I can only get around 20 MPH out of it right now. The motor was in meed of some maintenance and I have completed most of it. The only 2 things left to do right now are installing a new kill switch and a new tiny tach. Neither are working.
So I do not know how many rpms I am turning. What should it turn (max) in water and out?
I did just yesterday change out the air filter which looked horrible. Could this cause a loss of rpms and speed? I have not had a chance to run it yet.
My other concern would be the prop. It has a 3 blade on it and it looks a little worn to me. It is smooth and rounded, much different from my boat props. Should the blades be edged and defined?
What is the best prop for this motor?
I would appreciate any input on the above.
Thanks
Thu Sep 19, 2013 7:44 am
postalpaul
Joined: Sun Nov 01, 2009 6:25 pm Posts: 1935 Location: Kaufman- TEXAS
Users browsing this forum: Majestic-12 [Bot] and 322 guests
