Your solution to securing bilge pump to boat bottom?
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=45929
Author:  dguidry [ Sun Sep 29, 2013 11:32 am ]
Post subject:  Your solution to securing bilge pump to boat bottom?
Glue bracket to bottom?
Other solution?
Author:  MNGunner [ Sun Sep 29, 2013 11:34 am ]
Post subject:  Re: Your solution to securing bilge pump to boat bottom?
Author:  msm8281 [ Sun Sep 29, 2013 11:38 am ]
Mount it to a 6"x6" piece of aluminum plate.
Author:  CAJUN OUTLAW [ Sun Sep 29, 2013 12:05 pm ]
Some people should just stay on land.
Author:  Woodiebuster [ Sun Sep 29, 2013 12:26 pm ]
duct tape it
Author:  Will [ Sun Sep 29, 2013 12:33 pm ]
http://www.3m.com/product/information/M ... alant.html
Author:  JIMMY W [ Sun Sep 29, 2013 1:30 pm ]
5200
Author:  rudyeng [ Sun Sep 29, 2013 2:45 pm ]
I did it 3 ways until I got it perfect. This is the best
1. 80 grit sandpaper aluminum & bottom of bilge pump
2. Black 5200
Works great.
Author:  TX Aggie '06 [ Sun Sep 29, 2013 3:31 pm ]
Mine is held down by gravity and in place the rigid tubing that goes out the side of the hull.
Sent from my iPhone using Tapatalk -
Author:  JLACOUR [ Sun Sep 29, 2013 4:30 pm ]
Where do you buy that gravity stuff?
Author:  squirrel [ Sun Sep 29, 2013 4:41 pm ]
Wood screws.
Author:  naj [ Sun Sep 29, 2013 4:44 pm ]
Author:  dfou [ Sun Sep 29, 2013 4:47 pm ]
Author:  Over the LINE [ Sun Sep 29, 2013 4:58 pm ]
Mine is plumbed overboard via a PVC pipe that I heat bent to conform to where it runs then 90 degree over the transom. I wire tie the PVC along side my motor mount. Has worked well for years.
Author:  dguidry [ Sun Sep 29, 2013 5:00 pm ]
Author:  Woodiebuster [ Sun Sep 29, 2013 6:42 pm ]
5200 is gunna make a mess when you have to take that cheap bilge pump out to put a new one in.
I always just kept one under the deck in a bag, hook up some alligator clamps to the battery and stick the hose over.
I cant stand anything fixed stationary in a boat.
Author:  Full Throttle [ Sun Sep 29, 2013 6:47 pm ]
Author:  msm8281 [ Sun Sep 29, 2013 6:57 pm ]
Author:  North LA Hunter [ Sun Sep 29, 2013 7:20 pm ]
I broke a piece of 1/8 however big the pump is square and added 3/4 lip broke up with the side. Put the bottom of the square piece on the bottom of the boat and run the 3/4 up the side. Before I welded it down I took the screen off of the pump and riveted it to the piece of metal. Tack it in good and if the screen ever breaks just take a chisel and break the tacks off. I've did this to 3 boats and I'm pretty rough on my stuff and nothing has ever broke on them.
Author:  dguidry [ Sun Sep 29, 2013 7:49 pm ]
Author:  eljefe [ Sun Sep 29, 2013 10:10 pm ]
Mines just sits there...why do you need it secured? The tubing should keep it from moving much...... mines worked perfect since ive had the new boat....
sent from the former Republic of Texas.
Author:  JLACOUR [ Wed Oct 02, 2013 8:34 pm ]
Cause that the way it came!
Author:  eljefe [ Wed Oct 02, 2013 8:48 pm ]
You need like 50 of those jesse.. :lol: :lol:
Author:  JLACOUR [ Wed Oct 02, 2013 8:51 pm ]
:lol: I hope not in this boat!
