Lately I been having trouble with things cracking like carb brackets ring terminals for ma trim exhaust heat shields on side the motor. So I started checking and I noticed some marks on the back side on where the belt rides and its moving bout 1/2 inch from when its idling to when its in neutral when you put it in hear it moves back off the gear it rides on
You do not have the required permissions to view the files attached to this post. _________________ 2010 gtr cdi with a stage 2 pushing a 18x46 home made HEAVY DUTY boat
Sun Oct 06, 2013 3:05 pm
jc
Re: Don't think this is supposed to move how to fix
Something is loose but i can't tell what. I see your bolt on the banjo fitting on the brake caliper is hitting the frame and moving around. Check your caliper bolts and your motor mounting bolts.
Sun Oct 06, 2013 6:11 pm
benelli08
Ill check them Tom and get back
Users browsing this forum: No registered users and 133 guests
