Need advice
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=46068
Author:  odha [ Fri Oct 04, 2013 2:32 pm ]
Post subject:  Need advice
I just bought a gator tail 35hp with reverse and hydraulic trim.
I had been running a long tail and a GD short tail.
With those motors when I hit a stump the prop would pop up then I had to get hold of the tiller again. With this new rig I don't see that hapenning.
So any advice from those of you with experiance running in stump filled waters. I will hit stumps, so is there anything I can do to keep from damaging my prop, clutch and drive belt?
Author:  naj [ Fri Oct 04, 2013 2:39 pm ]
Post subject:  Re: Need advice
Are you saying the "lower unit" and prop is not popping up when hitting stumps.
Author:  North LA Hunter [ Fri Oct 04, 2013 2:39 pm ]
I run plenty of stumps and have never damaged a prop (other than a piece of steel I hit) or belt or anything else.
This motor is weighted back so when you hit a stump it will fall back in the water.
Is that what you were asking?
Author:  Bigrich [ Fri Oct 04, 2013 3:27 pm ]
Motor will kick up! I have a buddy that damaged his prop on a stump not typical but just one them bad luck days! I thought I had a pic but he is on here so may b he will post a pic of his prop
Author:  North LA Hunter [ Fri Oct 04, 2013 3:31 pm ]
Don't hit any steel. If you can't tell that's about 1/2 to 5/8 turned on 90 degrees.
Sent from my beeper.
Author:  Bigrich [ Fri Oct 04, 2013 3:32 pm ]
Lucky u didn't bend your drive on that one
Author:  Woodiebuster [ Fri Oct 04, 2013 6:36 pm ]
Bet it shakes nicely now!
Author:  bayouboy [ Fri Oct 04, 2013 7:19 pm ]
Mercy!
Author:  odha [ Fri Oct 04, 2013 9:31 pm ]
I haven't hit a stump with it yet. I've only had it three days. I am wondering if the hydralic trim will prevent the prop-lower unit from popping up when the prop striks a stump.
I sure don't want to hit any steal. There are a few old brigde pillings made of steal that I know of that I've always avoided.
While running accross the stump filled mud flats should I trim the lower unit low in the water as the manuel states for running in mud or keep it shallow as it says for running on sand.
Author:  OwenDickeson [ Fri Oct 04, 2013 9:38 pm ]
If running stumpy waters keep the motor trimmed as high as possible while being able to maintain speed.
The motor will kick up when you hit a stump, don't worry about it.
Author:  dirtybird29+ [ Fri Oct 04, 2013 10:12 pm ]
