Question about prop http://mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=46145 |
Author: | jellyhead22 [ Mon Oct 07, 2013 3:33 pm ] |
Post subject: | Question about prop |
When i first purchased my 35 sport mb, the prop had some play to it where you could move it back and forth.Is this common? Also now it does not do this anymore. Should the prop have some play in it or none at all? |
Author: | North LA Hunter [ Mon Oct 07, 2013 3:35 pm ] |
Post subject: | Re: Question about prop |
Back and forth as in sliding on the shaft? If so the prop nut needs to be tightened. Shouldn't be any play in the prop. Sent from my beeper. |
Author: | jellyhead22 [ Mon Oct 07, 2013 4:12 pm ] |
Its not sliding back and forth (north to south) on the shaft but a slight rock laterally (east to west) if this helps |
Author: | North LA Hunter [ Mon Oct 07, 2013 4:21 pm ] |
My mb did that after I filed the shaft to put the Hopkins on it. Only did it with the big blade but it didn't hurt anything on mine. It's probably in a bind now. I would just leave it if there is no play in it now. Sent from my beeper. |
Author: | jellyhead22 [ Wed Oct 09, 2013 9:13 pm ] |
Ok will do. Thanks for the responses MMT brothers |
