It is currently Mon Jul 07, 2025 6:34 pm
Reply to topic  [ 27 posts ]
 MUD BUDDY 5500 MAG HELP
Post MUD BUDDY 5500 MAG HELP
Took the boat out this weekend and it ran great for the first half of the day Saturday. Later that afternoon I ran it again and it ran fine until I would spin over 4200 rpms or so then it would back fire and shut off. I started it back up and same thing happened, luckily I was right by the house and idled in. I tried to start the motor the next morning with no luck until finally it decided to turn over. I took it out and it ran like a champ and idles great now but still doesn't want to start at all. The motor has 35 hours on it and has never had any issues. Any advice would be appreciated.
Mon Jun 17, 2013 8:11 am
Post Re: MUD BUDDY 5500 MAG HELP
Try disconnecting the rev limiter the next time it won't start. Should be a green wire.
1648 gd hull flying in front of a stage 3 with fpr
Mon Jun 17, 2013 8:36 am
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Mon Jun 17, 2013 7:59 pm
What if he has a CDI motor then?
Mon Jun 17, 2013 8:16 pm
Then he wouldn't have a 5500 MAG
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Mon Jun 17, 2013 8:21 pm
Mon Jun 17, 2013 9:40 pm
Mon Jun 17, 2013 10:03 pm
I'm trying to save my dignity from overlooking the obvious :lol:
Mon Jun 17, 2013 10:16 pm
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Mon Jun 17, 2013 10:18 pm
Mon Jun 17, 2013 10:43 pm
You sure? I thought that was same motor, but with "cooler" name.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Mon Jun 17, 2013 10:56 pm
Mon Jun 17, 2013 10:58 pm
BAMF and MAG are same engine they are both non CDI...the BD models are the CDI, but none of the BLACK DEATH models have the internals. If it is CDI won't the wrong clearance on the coils cause it to lose RPM like he is describing?
F-4 5500 BAMF-Sold
Stage 1 GTR- deciding on a boat
Mon Jun 17, 2013 11:43 pm
Tue Jun 18, 2013 4:27 am
I have been looking and i cant find out what BAMF stands for? I am sorry if this is a stupid question. Please dont bash me.
1651 Excel Viper W/ MB HD 35 Stage 2
Tue Jun 18, 2013 7:02 am
it is actually reffered to as just Mag 5500
somewhere along the way they created a decal for the front of the engine labeled 5500 bamf
b-bad
a-ass
m-mutha
f-fu**er
Tue Jun 18, 2013 7:11 am
I think mainly because many people prefer the single mikuni carb over the dual setup, that and because of not having any stock components
This motor has been put on a dyno and produced 52 hp.
Tue Jun 18, 2013 7:14 am
All the 5500 mags/bamf r now cdi"s.... Bamf is just a term... It is still a 5500 mag.
As for your issue sounds to me like your plug wires may be rubbed at the cowling. When this happens the motor will do exactly what you are saying when the wires get wet... Check this first...
This would explain why it is fine at times and not others also
Prodigy Boats
https://www.facebook.com/Prodigyboats
www.prodigyboats.com
Contact for info - http://prodigyboats.com/contact-us/
706-253-7766
Tue Jun 18, 2013 7:16 am
Thanks for the help. Tried starting it last night and had the same issue until I found the loose connection. Now it cranks and runs like new.
Tue Jun 18, 2013 9:02 am
where was the loose connection? might help someone else with the same issue someday....
Glad you got it back up and running
Tue Jun 18, 2013 9:46 am
I disconnected then re connected all my wires and noticed a few were slightly loose, but one of my ground wires was hardly connected. Not sure which wire was the actual cause of the problem.
Tue Jun 18, 2013 10:12 am
Wed Oct 16, 2013 10:23 pm
Wed Oct 16, 2013 10:28 pm
Gus, the HD 5500 runs best at 4500-4550 rpms with a normal load (what this means to each person is up for debate).This is from experience, as well as advice from Boat dr. This is the rpm target to ensure you have the right gears for your what ever set up you have.
Thu Oct 17, 2013 7:01 am
apologies to the Georgian Cajun for the insult. :-P
for me, a load is three guys (600lbs), and my two boys (165lbs - one dog/one human) and dekes. that's why I am going with the 1860.
you guys agree that the BD5500 will struggle?! I just worry that with my luck i'll hit the 1% lottery on the 5500 MAG/BAMF/WTF ELSE YOU WANNA CALL IT...
Thu Oct 17, 2013 7:45 am
That boat will run fine with the BD5500 (Stock Internals). My last boat was an older 2004 Gatortrax 20x54 with the BD5500 on it. It had no problem getting on step with 8 guys in it. We are at a higher (4500ft) altitude as well. Most of your load carrying ability will come from having the larger boat with more running surface.
Thu Oct 17, 2013 1:00 pm
Dkd.. Pm me your number...
Prodigy Boats
706-253-7766
Fri Oct 18, 2013 9:58 pm
Users browsing this forum: No registered users and 111 guests
