Gutted stocker http://mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=47070 |
Author: | North LA Hunter [ Mon Nov 04, 2013 5:24 pm ] |
Post subject: | Gutted stocker |
Well I got the mm blues because I've got no motor to play with so I threw my 12 hp on a longtail frame a buddy of mine built. The muffler outlets came out of the side pointing directly to the u joint. So I figured I would gut and relocate outlets. I'm hoping to get around 10 hp out of this mod. Maybe throw a mikuni on it and get another 10 hp or so out of it with that. Pretty soon I will have a 33 hp motor!! I'm shooting for around 30-35 mph out of this motor with a 12x12 prop. Y'all think it will push that prop okay?? Some may call it niqqer rigged but I call it a presidential solution. Before After Sent from my beeper. |
Author: | North LA Hunter [ Mon Nov 04, 2013 7:09 pm ] |
Post subject: | Re: Gutted stocker |
Surely y'all didn't think I was serious???!!! Sent from my beeper. |
Author: | cr244 [ Tue Nov 05, 2013 6:57 am ] |
i did but that exhaust will only get you 9.4 hp. LOL and i love (presidential solution) i will steal that and use it. that is some funny stuff |
Author: | Gray Goose [ Tue Nov 05, 2013 12:11 pm ] |
If you turn the pipes down you can get 9.8 HP out of it.. ![]() ![]() |
Author: | North LA Hunter [ Tue Nov 05, 2013 1:19 pm ] |
Did some mods to stock carb. Sharpen up everything and grind bolts down and did a little bit. Removed governor rod to carb and rev it up till valves float. Runs good until then!! Sent from my beeper. |
Author: | Woodiebuster [ Tue Nov 05, 2013 7:56 pm ] |
Them wardens are gunna know sumthins up when you are runnin 20 mph with a load! |
Author: | North LA Hunter [ Tue Nov 05, 2013 7:58 pm ] |
Author: | Will B Free [ Mon Nov 11, 2013 8:48 pm ] |
How much performance does that gutted stock actually do ? I'm a newbie to engine modes and looking for some easy reliable mods for my 12 horse |
Author: | North LA Hunter [ Mon Nov 11, 2013 8:59 pm ] |
Not a whole lot but I'm sure it does a little good. Get a carb and a cam and billet connecting rod and remove governor. Might be a little money but it would be well worth it. And if its a lct motor pull the back case off and check connecting rod. They are well known for the bolts on the caps to come loose and throw a rod. Sent from my beeper. |
Author: | Will B Free [ Mon Nov 11, 2013 10:40 pm ] |
And these will hold up over time? Ive heard a lot about these mods tearing up engines |
Author: | North LA Hunter [ Tue Nov 12, 2013 8:07 am ] |
Author: | Will B Free [ Tue Nov 12, 2013 8:37 am ] |
I appreciate the insight. I don't know if I'm up to the mods as repairs might be a little out of my league |
