transmission for inboards http://mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=51121 |
Author: | banded-mallard [ Wed Mar 05, 2014 2:37 pm ] |
Post subject: | transmission for inboards |
For those with inboard mudboats, where did you get your transmission? |
Author: | forever draggin [ Wed Mar 05, 2014 3:34 pm ] |
Post subject: | Re: transmission for inboards |
Louisiana power on hwy 182 n houma or m&l on at Charles. For what's it's worth they had a rebuilt hurth on the sportsman yesterday for like 600 I believe. A new one will b over 2k |
Author: | banded-mallard [ Thu Mar 06, 2014 5:54 am ] |
Author: | swamprat26 [ Thu Mar 06, 2014 7:52 am ] |
The first one I had I bought off Ebay for &100. It was a sailboat shop. Bought a $100 rebuild kit. They are very simple to rebuild. $200. That was is 2005. Trans has over 900 hours on it and still running Sent from my iPhone using Tapatalk |
Author: | dguidry [ Thu Mar 06, 2014 8:01 am ] |
Forever Dragging may be a pirate ninja but he knows his stuff about inboard transmissions. They ain't cheap. The alternative is direct drive with no reverse. |
Author: | tchauvin [ Thu Mar 06, 2014 9:02 am ] |
M&L in houma had them at one time... Thats if you are talking about the little air cooled ones. If velvet drive, buy used and rebuld for cheap cheap... |
Author: | forever draggin [ Thu Mar 06, 2014 9:04 am ] |
M&l carries both, they just high as shit |
Author: | North LA Hunter [ Thu Mar 06, 2014 9:22 am ] |
Author: | tchauvin [ Thu Mar 06, 2014 9:28 am ] |
Author: | banded-mallard [ Thu Mar 06, 2014 10:43 am ] |
Were looking at throwing something together to cut some ditches on our lease. Podna ran across a subaru engine and were thinking about doing it. |
Author: | tchauvin [ Thu Mar 06, 2014 10:46 am ] |
BM, if your lease is overgrown bAd a Subaru might not get it done. I had a 15/48 with a v-6 and behind decade it was just enough to cut it. FYI... |
Author: | swamprat26 [ Thu Mar 06, 2014 10:58 am ] |
All depends on the reduction. Also the hydraulic clutch will rob 20% of your horsepower Sent from my iPhone using Tapatalk |
Author: | forever draggin [ Thu Mar 06, 2014 11:03 am ] |
Author: | swamprat26 [ Thu Mar 06, 2014 11:22 am ] |
Keep this in mind when building an inboard. Most Subaru's run a velvet drive 1:1 ratio turning a 11x11 wheel usually around 4500 rpms. Take an 80 hp engine minus 20% power loss = 64hp. My briggs inboard with mechanical clutch 1.5:1 ratio turns an 11x12 at 4300rpm engine speed. That subaru will walk the dog on my boat in open water. In lilies I have the upper hand. Sent from my iPhone using Tapatalk |
Author: | forever draggin [ Thu Mar 06, 2014 11:25 am ] |
Subarus run a 10x10 with 1:1 usually |
Author: | swamprat26 [ Thu Mar 06, 2014 11:27 am ] |
I was talking the bigger subaru so as not to hurt feelings. But you are correct Sent from my iPhone using Tapatalk |
Author: | forever draggin [ Thu Mar 06, 2014 11:30 am ] |
So am I. The ea82s run a 10x10 |
Author: | swamprat26 [ Thu Mar 06, 2014 11:31 am ] |
So you proved my point further. Titts or stfu Sent from my iPhone using Tapatalk |
Author: | banded-mallard [ Thu Mar 06, 2014 11:39 am ] |
Author: | forever draggin [ Thu Mar 06, 2014 11:51 am ] |
Nothing wrong with a Subaru. I've been n subarus that walked the dog on a 302. Reduction is everything. Get a 1.5:1 or a 2:1 and ull never look back |
Author: | pooldoo73 [ Sat Mar 08, 2014 1:19 pm ] |
Put a V8 in I with a 1:1 velvet drive r whatever. 14" wheel. Blacktop won't slow it down. |
Author: | lastchance [ Sat Mar 08, 2014 1:27 pm ] |
My brother and I built a 19x60 with a 454 1:1 velvet drive I could probably launch on dry ground and run to water it had a 19x19 wheel turning about 4000rpms |
