PD Engine shield. http://mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=51451 |
Page 1 of 2 |
Author: | North LA Hunter [ Fri Mar 14, 2014 9:01 am ] |
Post subject: | PD Engine shield. |
A guy brought in a pd with a guard built around that he wanted to rebuild. The one he has on it is 1/8 carbon and we are going to build ours out of 1/8 alum. I guess he wants it to look a little better and be tighter against the motor and more holes for ventilation. I will keep y'all posted as we build it. Maybe it will held some of y'all build some of your own if needed. Sent from my beeper |
Author: | cb5331 [ Fri Mar 14, 2014 9:04 am ] |
Post subject: | Re: PD Engine shield. |
That looks fucking retarded ![]() |
Author: | North LA Hunter [ Fri Mar 14, 2014 9:12 am ] |
Author: | Randy S [ Fri Mar 14, 2014 9:16 am ] |
I don't get it; what's the purpose of the shield? |
Author: | msm8281 [ Fri Mar 14, 2014 9:19 am ] |
Author: | North LA Hunter [ Fri Mar 14, 2014 9:21 am ] |
Author: | baron von [ Fri Mar 14, 2014 9:22 am ] |
Author: | North LA Hunter [ Fri Mar 14, 2014 9:27 am ] |
Author: | Randy S [ Fri Mar 14, 2014 9:29 am ] |
Author: | North LA Hunter [ Fri Mar 14, 2014 9:33 am ] |
He might meet to get a GTR! I've ran through alot of stuff through mine and had nothing pulled off! But doesn't make sense because its the same chit just laying down. Maybe he's just very very rough with it! Sent from my beeper |
Author: | LAduckbuster [ Fri Mar 14, 2014 9:45 am ] |
Maybe he is ashamed of his motor and just wants to cover it up, ya know like the fat kid that wears a shirt at the pool Sent from my iPhone using Tapatalk |
Author: | LAduckbuster [ Fri Mar 14, 2014 9:46 am ] |
Author: | North LA Hunter [ Fri Mar 14, 2014 9:50 am ] |
Author: | North LA Hunter [ Fri Mar 14, 2014 9:51 am ] |
Author: | bayouboy [ Fri Mar 14, 2014 9:57 am ] |
Author: | bayouboy [ Fri Mar 14, 2014 9:59 am ] |
Author: | North LA Hunter [ Fri Mar 14, 2014 10:03 am ] |
Author: | caddobrook [ Fri Mar 14, 2014 10:07 am ] |
He does understand that these are AIR cooled motors, right? There is a MUCH better way to secure wiring than impeding the flow of air to your motor. That spells trouble to me..... Don't care how many vent holes you put, you are creating a space to trap heat, and choking the air flow around the motor. These motors are designed to flow air in a certain way and when you mess with that, you are asking for trouble. I would charge him for NOT building it for him, kick him in the nuts, and send him on his way. Have run thru tons of brush and thickets, and if you secure your wiring, you should have no problem. |
Author: | North LA Hunter [ Fri Mar 14, 2014 10:11 am ] |
He knows a guy that has one that is more ventilated and he has had it for 2+ years. I was worried about it myself but he has had this one for about 2 seasons now and no problems. He is wealthy man and I'm thinking about writing something in the invoice saying that we are not liable for anything having to do with and engine problems. And I think the only time this motor is ran is in the winter. Sent from my beeper |
Author: | Will [ Fri Mar 14, 2014 10:15 am ] |
I've been through shit where I had to lay in the floor and hold the gas, never ripped anything off ![]() |
Author: | baron von [ Fri Mar 14, 2014 10:18 am ] |
get back to work - I am intrigued and want to see how you crack this nut and what the final product is going to be |
Author: | bayouboy [ Fri Mar 14, 2014 10:22 am ] |
Ehh, every lawn mower I've ever seen has a hood/ cover over it. As long as you don't impede air flow to the blower/fan and don't trap in exhaust heat it should be fine. But in all reality, Most of the wiring is safely tucked in behind the tiller. So imo the things that actually need the most protection would be the oil cooler and filter. a simple 1/8 shroud around them would do the job just fine. I would also think about making a skid plate to go over the air filter box. Same thing 1/8 plate and utilize the 2 back fan guard bolts to hold it on. In laymans terms instead of building one fugly big ole box, make a few small protective shrouds. |
Author: | LAduckbuster [ Fri Mar 14, 2014 10:24 am ] |
I got a buddy with a pd and one with gtr so I been in the middle of the argument for a couple years already Sent from my iPhone using Tapatalk |
Author: | bayouboy [ Fri Mar 14, 2014 10:32 am ] |
Author: | OwenDickeson [ Fri Mar 14, 2014 10:51 am ] |
I would cover the oil cooler, and try to do a small cover for all the wires around the starter, and maybe a small piece covering the spark plug wires and make sure the fuel line is covered. PD has a brace for the fuel line where it goes into the fuel pump. It will help keep from breaking off the plastic fitting on the fuel pump if your fuel line gets snagged. |
Author: | North LA Hunter [ Fri Mar 14, 2014 11:28 am ] |
These are the pictures of his buddies. Looks like its a little more tucked in tighter to the motor. Sent from my beeper |
Author: | bayouboy [ Fri Mar 14, 2014 11:39 am ] |
That one looks a little better, but not by much. lol I'm sure you can do better!! |
Author: | Will [ Fri Mar 14, 2014 11:40 am ] |
Author: | caddobrook [ Fri Mar 14, 2014 1:50 pm ] |
Author: | Woodiebuster [ Fri Mar 14, 2014 7:14 pm ] |
If you had something blocking the fan from pulling in air that might hurt it, but that surrounding it shouldn't. It wont hurt it any worse than those retarded oil coolers people put on the flywheel cover. I think it is a good idea to have the tiller controls protected, but I think having them off the tiller and in the boat somewhere would keep them from ever getting bent back or torn off. I might would trim it down around the front where it isn't so gawdy and just have a tight fitting shroud around the sides that fits low to the plastic shroud. That would look pretty sharp! |
Author: | VooDoo Daddy [ Fri Mar 14, 2014 9:04 pm ] |
Author: | Will [ Sat Mar 15, 2014 10:09 am ] |
Nah, was at least 3' deep |
Author: | dillakilla12 [ Sat Mar 15, 2014 10:16 am ] |
That looked sketchy Will! Sent from my SM-N900V using Tapatalk |
Author: | Will [ Sat Mar 15, 2014 6:23 pm ] |
Only thing that was concerning me was catching a moccasin in the lap ![]() |
Author: | 50fps [ Sat Mar 15, 2014 7:00 pm ] |
Does the customer fish for alligators? |
Author: | North LA Hunter [ Sat Mar 15, 2014 8:17 pm ] |
Author: | THE TANK [ Sat Mar 15, 2014 8:27 pm ] |
Author: | North LA Hunter [ Tue Mar 25, 2014 12:48 pm ] |
Got it on there. Still have some trimming and holes to put in it. Still looks like crap though. Sent from my beeper |
Author: | NORTHFLORIDAFOWLER [ Tue Mar 25, 2014 12:52 pm ] |
i hope this motor doesnt end up like wills generator when you put a cover around it!!! ![]() |
Author: | OwenDickeson [ Tue Mar 25, 2014 1:26 pm ] |
wow Sent from my XT1080 using Tapatalk |
Page 1 of 2 | All times are UTC - 6 hours |
