It is currently Wed Jul 02, 2025 1:54 am
Reply to topic  [ 19 posts ]
 What size mud motor for a 1448 polar kraft?
Post What size mud motor for a 1448 polar kraft?
Hi I was wondering if any one had an idea what size, or brand. would be the best for my boat? I want to be able to push between 20 and 25 mph. long tail or surface drive.
Sun May 11, 2014 8:00 pm
Post Re: What size mud motor for a 1448 polar kraft?
An outboard unless it's a mud hull. A true flat bottom.
Semper Fi
16x38 WC Skiff 35 MB HD
Sun May 11, 2014 8:04 pm
If you want to stick with your hull. My 18dixie pushes my heavy 1448grizzly modv in the lower 20s, but i think an 18 copperhead would push faster maby.
Sun May 11, 2014 8:20 pm
does it have a flat front or a mod v. If it has a mod v you will be dissappointed. Keep it light either a mud buddy mini 23 or 27 or a 23 copperhead. Weight is going to be about the same with an 18 compared to a 23 so get the 5 extra ponies you will be glad you did. my 1448 with a 23 MBHD sucked too much weight on the transom a long tail is better on that boat. Either save your money for a longer 17'+ boat and a surface drive or get a long tail for now and save your money for when you can afford the proper set up for a surface drive. I sold my 1448 after 3 months because the motor needs a longer hull to perform like it was designed to do.
Mon May 12, 2014 9:11 am
I have an 18hp copperhead on a 14/48 monark. 26 mph by myself, 23 with 2 men, 18 with 3 men, if your going to have a light load and want to save 500$ the 18 is a great running motor. If your wanting to haul a little bigger load and/or mod the motor, get the 23 and you wont regret it!
Tue May 13, 2014 10:48 am
Tue May 20, 2014 9:06 pm
ive got a 23 mini on a 14x48 triton. runs 25-26 with me, the wife and a light load. buddy has a 14x48 polar that is very close in size to my triton. (not all 14x48's are the same size, his polar and my triton are very wide all the way to the bow, thus more surface area to the bottom, more weight to the front) i think they would run about the same.
Thu May 22, 2014 6:44 am
Thu May 22, 2014 11:23 am
Thu May 22, 2014 3:18 pm
Most 25's wiegh around 85lbs. My 35 GT is 263 lbs, most 25's surface drives are around 235 lbs . 150lb is a big increase on the back of your boat. plus the torque and pounding on the boat will be much greater.
Thu May 22, 2014 8:10 pm
Sat May 24, 2014 5:12 pm
23 mb sport?
B. MacDonald
Sun May 25, 2014 4:15 am
Mon May 26, 2014 1:47 pm
I have a go devil surface drive on my 14/48 handles it good we put 3 people and a dog in it all the time and run in 3 inches of water
18x48 extreme with 37 gtr
past boats
07 gtr on 16x54 alweld
Mon May 26, 2014 6:14 pm
I run an HD sport and I am so glad I went with power trim and neutral instead of getting the mini. Because of the way the 1448 handled I was constantly adjusting the trim. But it really was just too much weight on the transom and hurt performance. Honestly if your dead set on getting a SD get what you really want now run it for a season or two and upgrade the boat to something that runs better with that motor. It's a lot of peanuts to drop on a motor and be disapointed with it.
The joy of having that new motor and being able to get through all that shit you care to run through will wear off soon when it doesn't perform like you thought it would. I would lighten the boat up as much as you can removing plywood and get the battery and gas up front to balance the load. Good luck with whatever you choose
If you have a flat front you will be fine if its a mod v you will have problems
Mon May 26, 2014 8:25 pm
Had an 18 hp on a 1448 Lowe that ran like a raped date. Don't thing the transom would have taken more.
http://www.gatorglide.com/
gatorheads@comcast.net
Tue May 27, 2014 4:58 am
Fri May 30, 2014 2:39 pm
Since you have a mod v performance isn't going to be great so I would find a used longtail this will get you where you need to go for the time being. If you were to buy an SD for this boat your limiting your self on what type of motor and size boat you will be able to upgrade to in the future if you want to keep the motor and want better performance. It cheaper in the long run to buy a used LT run it for a couple years while saving money and then sell the old rig and get a combo that will work well together.
It's your money so if your dead set on a SD get it. If I knew how my 1448 was going to perform I would have waited another year and got a bigger boat and a 35. It's cheaper to do it right the first time
Sat May 31, 2014 7:50 pm
Sat May 31, 2014 9:23 pm
Users browsing this forum: No registered users and 159 guests
