Second trim switch on grab handle
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=53715
Page 1 of 2
Author:  swo [ Tue Jun 03, 2014 5:48 pm ]
Post subject:  Second trim switch on grab handle
Can anyone explainhow to hook up a second trim switch and solenoid to a GTR35 that has the trim on the tiller now.
Author:  doubleBanded [ Tue Jun 03, 2014 6:02 pm ]
Post subject:  Re: Second trim switch on grab handle
I believe handle is one of the ones that changed his
Author:  banded-mallard [ Wed Jun 04, 2014 5:17 am ]
Author:  swo [ Wed Jun 04, 2014 6:54 am ]
Thanks banded-mallard. I have looked at the trim on my motor and there are 2 wires coming from it, blue-up and green-down. I have not opened up the wiring harness yet to locate where these wires go. What i am trying to accomplish is to keep my trim switch on the tiller and also add one to the grab bar.
Author:  Will [ Wed Jun 04, 2014 6:55 am ]
Should be as simple as adding another switch and wiring it exactly the same as the existing to the same terminals...
Author:  tyler_johnson [ Wed Jun 04, 2014 7:01 am ]
Supposedly it isn't as easy as it looks. There is also a ground shunt in the factory trim that makes you have to reverse polarity or some crap. But that is what I have been told. If someone figures this out I will applaude you and copy what you did!! :lol: :lol:
Author:  Bigrich [ Wed Jun 04, 2014 7:02 am ]
May be pokey will get in on this I think he finally got it figured out.
Author:  tyler_johnson [ Wed Jun 04, 2014 7:04 am ]
haha that is him, I couldn't remember his name on here!
Author:  Bigrich [ Wed Jun 04, 2014 7:10 am ]
Muddonkey has it figured out he built my switch the problem seems to be that he won't answer pm's.
I have one his switches problem is I never hooked it up.
Swo how long have you been trying to get ahold of him? I believe is a machinist off shore but not 100% sure on that
Author:  Will [ Wed Jun 04, 2014 7:13 am ]
Why can't you tap into the same blue and green wire with the other switch? Same thing, the switch will close the circuit. Forget about the rest of it...
Author:  Bigrich [ Wed Jun 04, 2014 7:15 am ]
Not sure will says that will not work..... I agree with ya on your thinking!! I have never tried wiring the separate switch but they all says it lil something to it
Author:  Will [ Wed Jun 04, 2014 7:19 am ]
I'd have to see it. I used a reversing solenoid on my PD that was controlled by a simple rocker switch. Blue and green for up and down and a red for power from the starter. You could add 37 switches if you wanted, didn't matter which one was used to control the solenoid...
Author:  Bigrich [ Wed Jun 04, 2014 7:21 am ]
I'm with ya will
I done the same thing on a cmc plate but you couldn't pump the switches at the same time... Say never happen but someone in front pull and some in back pushing boat threw timber it alms it happened a couple times. I had switch in tillar handle and one on front the boat
Author:  Will [ Wed Jun 04, 2014 7:22 am ]
Same thing if it's wired like this... there's a trim switch controlling the relay, wire another one to the relay just like the existing one... why won't that work?
Author:  pokey79 [ Wed Jun 04, 2014 7:35 am ]
Because the stock switch has a ground shunt in it ! When the switch is not being used it shorts both motor power wires to ground
Author:  Will [ Wed Jun 04, 2014 7:41 am ]
That's fucked up. The above diagram shows the simple rocker switch controlling a relay powering the motor. With the rocker switch in the neutral position, the relay is open and not sending power to the motor. What is there to shunt?
Author:  pokey79 [ Wed Jun 04, 2014 7:43 am ]
And that drawing is the old setup when they used a relay now the switch is beefed up and on it's own it can handle 70 amps is why they did away with the relays! But if u buy a quality DC reversing solenoid u can use a 50 cent switch without burning it up! Now the secert is out yall have fun
Author:  pokey79 [ Wed Jun 04, 2014 7:50 am ]
Looks like this! I choice to buy from napa for 90 bucks cause the cheap ones online are made in China
Author:  pokey79 [ Wed Jun 04, 2014 7:52 am ]
And this is the route I went
Author:  Will [ Wed Jun 04, 2014 7:53 am ]
Author:  banded-mallard [ Wed Jun 04, 2014 7:56 am ]
Author:  pokey79 [ Wed Jun 04, 2014 8:00 am ]
Cole herse is the solenoid I used 90$ from napa
Author:  pokey79 [ Wed Jun 04, 2014 8:04 am ]
This is the one
http://www.colehersee.com/home/item/cat/189/24450/
Author:  Will [ Wed Jun 04, 2014 8:06 am ]
Prodrive had many brands tested and the Cole Hearse was one of the better ones but failed. The Trombetta cycled over 70,000 times without failure and the motor actually failed before the solenoid did so that's the one they use but they're $135ish each.
I used this one and didn't have a probelm with it and for that cheap you can have an extra if it does. :lol:
http://www.amazon.com/Reversing-Continu ... g+solenoid
With a rocker switch kit like this one. http://www.amazon.com/MotoAlliance-Hand ... nch+switch
Author:  Will [ Wed Jun 04, 2014 8:09 am ]
Here's the Trombetta
http://www.trombetta.com/cm/pdfs/D03924REVA.pdf
http://www.trombetta.com/cm/pdfs/Instal ... tactor.pdf
http://www.trombetta.com/dc-contactor-products.cfm?id=9
Author:  pokey79 [ Wed Jun 04, 2014 8:22 am ]
And this will answer y'all switch questions!
http://www.shallco.com/images/power_rocker.jpg
Author:  dwight37 [ Wed Jun 04, 2014 8:30 am ]
I mounted this on my oh shit handle
http://www.amazon.com/gp/aw/d/B0051US2L ... mp_s_a_1_4
Author:  RoyBoy10 [ Wed Jun 04, 2014 9:05 am ]
Marked for later.
Author:  swo [ Wed Jun 04, 2014 9:10 am ]
Bigrich, I pm'd him a couple days ago.
Pokey, I may sound like and idiot but I'm no electrian by far and have no clue about this stuff. I run the new switch to the reverse solenoid, run a hot from battery to solenoid, and do I jump from the existing solenoid to the new one. I want to be able to have both switches working.
Author:  bayouboy [ Wed Jun 04, 2014 10:00 am ]
Author:  pokey79 [ Wed Jun 04, 2014 8:22 pm ]
thanks bayou boy! :D but theres ur answer u cant run any extra switch's unless u disconnect the factory switch or change it out
Author:  swo [ Wed Jun 04, 2014 8:28 pm ]
Thanks guys for the help.
Author:  swo [ Wed Jun 04, 2014 9:06 pm ]
I also talked with GT, and they said that you could leave the factory switch in the box. He said take the reverse solenoid and run separate power to it, then run your second switch to it, and then tie into your trim wires.
Author:  bdavis85 [ Fri Jun 13, 2014 10:29 am ]
Does anyone have any pics of how to wire all this up.
Let me makes sure i get this right and do it the cheapest way possible. I can tap into the green and blue wires coming into the existing trim switch. I can get a solenoid and run the power through that. Then i should be able to use both the new and existing trim switches.
Where do you mount the solenoid?
Author:  mizzippi jb [ Fri Jun 13, 2014 11:01 am ]
Author:  Will [ Fri Jun 13, 2014 11:04 am ]
Author:  mizzippi jb [ Fri Jun 13, 2014 2:43 pm ]
Author:  swo [ Fri Jun 13, 2014 4:12 pm ]
The second time I talked to them they wasn't for sure if you had to disconnect the existing switch or not. According to pokey & BB you have to.
Author:  bayouboy [ Sat Jun 14, 2014 2:53 pm ]
The stock switch will not work. To keep it simple the stock switch will feed a positive voltage to both poles on the solenoid ( up and down) when you use the second switch.
Author:  mizzippi jb [ Sat Jun 14, 2014 4:09 pm ]
Page 1 of 2 All times are UTC - 6 hours
