how do you guys anchor your MM handles?
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=54066
Author:  GeeLeDouche [ Wed Jun 18, 2014 11:48 am ]
Post subject:  how do you guys anchor your MM handles?
I have long driven a 16 GDLT on a little 1436 alumacraft that has been a LOT of fun. one of the best investments of my life. but I just upgraded to a 1648 with a 31 mud buddy short shaft and I know very little about it. How do I anchor the handle on this short shaft so the motor doesn't flop around while Im driving?? do I just let it swing freely or do I use a bungee tie down on the motor handle? or what?? Thanks guys!
The Gee
Author:  basinhunter2012 [ Wed Jun 18, 2014 11:58 am ]
Post subject:  Re: how do you guys anchor your MM handles?
this screwed into your floor and attach a short rope..tie your handle down to it or you can do a rope across your boat and make a loop around your handle so it cant move
but should have a travel lock on it
Author:  270Handiman [ Wed Jun 18, 2014 12:02 pm ]
No travel lock on it? Is it an early production model?
Author:  fowllife08 [ Wed Jun 18, 2014 1:42 pm ]
Author:  basinhunter2012 [ Wed Jun 18, 2014 1:53 pm ]
Author:  GeeLeDouche [ Wed Jun 18, 2014 2:21 pm ]
Author:  DmaxHunter [ Wed Jun 18, 2014 2:29 pm ]
It's in right hand side of frame, you pick motor up while it's straight and push ball in. Locks motor up and straight for travel.
Samsung S5
Author:  mudslut [ Wed Jun 18, 2014 5:53 pm ]
I used the ratchet strap that held my boat on the trailer. I bolted a small piece of strap to the main strap right where the handle met the strap. The motor still moved a lil but not enough to hurt anything.
Author:  lunacris [ Wed Jun 18, 2014 6:16 pm ]
travel lock does nothing for the tiller handle. i bungee mine to one of the stringers by my false trans (has the hole for water flow). if thats what your talking about gee
Author:  Mayhem73 [ Wed Jun 18, 2014 9:29 pm ]
Use a transom saver and run a gunnel strap across that rear bench looped around the handle.
Author:  Mayhem73 [ Wed Jun 18, 2014 9:30 pm ]
Author:  riverratdm84 [ Thu Jun 19, 2014 7:54 am ]
There is a notch it sits in when in the travel lock position to keep it from swingin side to side.
Author:  GeeLeDouche [ Thu Jun 19, 2014 10:06 am ]
I don't see anywhere that has a travel lock on my motor.. I'll probably get a transom saver and strap like Mayhem said. Im sure He knows this boat better than I do. ;)
Author:  Mayhem73 [ Thu Jun 19, 2014 10:24 am ]
Let me know if you need any help with the old girl..
Author:  GeeLeDouche [ Thu Jun 19, 2014 10:33 am ]
Will do, thank you! I really appreciate it. Any idea what length of transom saver I should get? or are they all adjustable? maybe it would be easier to text me.. 801-991-0577. Thanks dude!
Author:  Mayhem73 [ Thu Jun 19, 2014 10:42 am ]
Get the one from Mudbuddy..
Author:  dead duk [ Thu Jun 26, 2014 7:28 pm ]
I used a transom saver and place the skeg in the wedge. Works well and the motor does not move when traveling. I tried posting a picture, but the file would not upload.
Author:  Sully504 [ Thu Jun 26, 2014 9:06 pm ]
I just make sure no one is inside my boat turning the steering wheel and that keeps my shaft from moving during travel.
CC
:lol:
Author:  kirk [ Fri Jun 27, 2014 10:33 pm ]
Author:  kirk [ Fri Jun 27, 2014 10:34 pm ]
