GeeLeDouche
 Any other company make high performance heads??
Im just wondering if "Iron Mountain" is the only place that sells things like aftermarket heads..?? and if anyone has used any other set and had good results? Just curious. Thanks guys!
The Gee
Tue Jul 01, 2014 2:14 pm |
msm8281
 Re: Any other company make high performance heads??
Any of these cats can hook you up with a mo betta set than IM.
Calen Hoyt Jamie B
Tue Jul 01, 2014 2:19 pm |
Mudmotor Slayer
Mms
Tue Jul 01, 2014 2:40 pm |
msm8281
I thought you said you didn't do heads??
Tue Jul 01, 2014 2:52 pm |
SCmudder7071
Al Hodge at Performance V-Twins.
_________________ 1754 Extreme/LAProp Stage 2 GTR
Tue Jul 01, 2014 3:04 pm |
Mudmotor Slayer
You give me 850 a set those guys charge I start doing them again lol
Tue Jul 01, 2014 3:14 pm |
AKA Freshwaterkilla
Tue Jul 01, 2014 3:48 pm |
msm8281
Tue Jul 01, 2014 4:01 pm |
AKA Freshwaterkilla
Tue Jul 01, 2014 4:10 pm |
ajverret
Joined: Sun Sep 29, 2013 5:33 pm Posts: 645 Location: New Iberia, La
Dat kick back tho lol
Sent from da mud hole
_________________ 1848 Uncle J and 37 EFI GTR
Tue Jul 01, 2014 7:26 pm |
msm8281
Tue Jul 01, 2014 7:32 pm |
cb5331
Tue Jul 01, 2014 7:59 pm |
cupped up
Joined: Tue Jun 05, 2012 7:25 pm Posts: 4205 Location: St. Amant, LA
Anybody ever look into the heads precision cams sells?
Tue Jul 01, 2014 8:43 pm |
msm8281
Tue Jul 01, 2014 8:45 pm |
270Handiman
Joined: Thu Dec 29, 2011 10:46 pm Posts: 2342 Location: Mandeville, LA
Tue Jul 01, 2014 9:06 pm |
LA Prop
_________________ 20' homemade skiff with a stage 2 gtr
Wed Jul 02, 2014 8:12 pm |
Rooterpig
Joined: Sat May 19, 2012 6:48 am Posts: 125 Location: East central Florida.
Calen did mine.
Fri Jul 04, 2014 6:20 am |
pokey79
Joined: Mon Nov 15, 2010 4:50 pm Posts: 2282 Location: Circumcised, Louisiana
Jamie B did mine!!!
Fri Jul 04, 2014 6:26 am |
krogers
Joined: Fri Oct 29, 2010 8:24 am Posts: 1958 Location: Bristol, FL
_________________ 1754 GTB / 35 GTR
Fri Jul 04, 2014 4:32 pm |
AKA Freshwaterkilla
Aka did mine Sent from my iPhone using
Fri Jul 04, 2014 5:04 pm |
cb5331
Fri Jul 04, 2014 5:07 pm |
benelliman
Joined: Wed Jan 14, 2009 10:54 am Posts: 532 Location: Livonia, La.
A person has to be out of their got dam mind to give someone $800.00 for a set of heads!I had mine done for less than $200.00.Find a competent machine shop that does heads and do the port and polish yourself.
Sat Jul 05, 2014 11:39 am |
odass
_________________ Dead Fowl Custom 1954hd with a GTR
Sat Jul 05, 2014 12:02 pm |
wisconsin phowler
Performance v-twin in North Carolina should have everything that you need... 704-291-7825
1756 Phowler 36PD
Sat Jul 05, 2014 2:11 pm |
Mudmotor Slayer
Finally a smart person !!!!!!
Sat Jul 05, 2014 2:12 pm |
AKA Freshwaterkilla
Sat Jul 05, 2014 4:11 pm |
Mudmotor Slayer
Sat Jul 05, 2014 4:43 pm |
GeeLeDouche
So... Whats the going rate to have one of these guys work over a set of heads?
Sun Jul 06, 2014 11:52 am |
wisconsin phowler
I think I paid $240 for decking, porting and the valve job. I went to my local speed/machine shop
1756 Phowler 36PD
Sun Jul 06, 2014 1:43 pm |
Gros'bec
Joined: Sat Jul 23, 2011 11:36 am Posts: 235 Location: Louisiana
Wayne at Harahan performance parts and machine shop estimates $250 to $500 depending on the condition of the heads. They use Manley stainless valves 504-737-0667
_________________ 18x44 Gator Trax, Stage 2 Mudbuddy
Wed Jul 09, 2014 1:51 pm |
Jamie B.
All of this head work depends on what is actually being done to the heads. I would be willing to bet that this is single angle valve jobs, casting knock downs and smoothing and decking. There wont be any port shaping, removing of valves guides and beveling, multi angle valve jobs with no lapping compound, deshrouding, polishing of combustion chamber and exhaust ports, valve stem cutting to keep stock geometry, new valve stem seals, and so on and so on. The only reason I made this post was to make people who are unaware of what goes on with the shops that charge higher rates. It was not ment to bash in any way so please don't take it that way.
Wed Jul 09, 2014 2:08 pm |
cb5331
^^hater
Wed Jul 09, 2014 3:55 pm |
Jamie B.
Wed Jul 09, 2014 4:03 pm |
Mudmotor Slayer
Looks like La prop does head work I hear he is pretty good
Mon Jul 14, 2014 12:17 pm |
Mudmotor Slayer
Mon Jul 14, 2014 3:35 pm |
THE TANK
Joined: Wed Mar 04, 2009 7:34 pm Posts: 1080 Location: Coteau Homles, La
Mon Jul 14, 2014 4:43 pm |
Mudmotor Slayer
Mon Jul 14, 2014 4:46 pm |
msm8281
So many people doing heads my head is spinning...lol
Mon Jul 14, 2014 4:51 pm |
Mudmotor Slayer
Lol
Mon Jul 14, 2014 6:12 pm |
Will
Tue Jul 15, 2014 3:59 am |
