BPS throttle http://mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=56467 |
Author: | Quack N Stack [ Tue Sep 09, 2014 7:27 pm ] |
Post subject: | BPS throttle |
I ordered the BPS throttle leaver to put on my go devil and like a dummy i didnt measure anything to make sure it would fit. Well i went to put it on earlier and the throttle is just a tad bit to small to fit around the handle. Anyone else have this problem and how did you fix it? I came up with two options, either find a piece of pipe that the throttle will fit well over and cut it to length i need and cut the tiller shorter then weld the new smaller piece in it's place. Or i can get longer screws that will reach then tighten it up then heat the tiller pipe with a torch and tighten the screws until the metal bends or warps to fit the hole for the throttle. Does this sound practical or a dumb idea? |
Author: | msm8281 [ Tue Sep 09, 2014 7:29 pm ] |
Post subject: | Re: BPS throttle |
Use a dremel and open it up some . That's what I did. |
Author: | Quack N Stack [ Tue Sep 09, 2014 7:39 pm ] |
Author: | msm8281 [ Tue Sep 09, 2014 7:45 pm ] |
Yes. Just keep taking material out till it fits. Careful its thin by one of the screw holes.. |
Author: | msm8281 [ Tue Sep 09, 2014 7:46 pm ] |
I can take a picture of it Friday. |
Author: | mudslut [ Tue Sep 09, 2014 7:49 pm ] |
Yea use a dremel. That's what I did also. Sent from my iPhone using Tapatalk |
Author: | Quack N Stack [ Tue Sep 09, 2014 7:50 pm ] |
Aight man thanks |
Author: | DUCK HEARSE [ Tue Sep 09, 2014 7:57 pm ] |
Author: | Duck GORE [ Wed Sep 10, 2014 2:17 pm ] |
You can just grind it bigger. |
Author: | baron von [ Wed Sep 10, 2014 3:25 pm ] |
be sure to dip coat handle - makes for great gripping surface viewtopic.php?f=3&t=53952 |
Author: | msm8281 [ Wed Sep 10, 2014 5:24 pm ] |
Take a little off everywhere, but take the most off here. Get rid of that hump. Those screws are cheap. Make sure to use some grease or it will gall up. |
Author: | baron von [ Sun Sep 21, 2014 10:04 am ] |
nice - actual pictures |
Author: | Quackkillz [ Sun Sep 21, 2014 12:15 pm ] |
Just finished doing the same thing. |
Author: | Pulpwood [ Tue Sep 23, 2014 6:18 am ] |
Had a machine shop take some off my handle. No modification to the throttle. $20 and was done. |
Author: | GatorDubea [ Tue Sep 23, 2014 6:28 am ] |
can you use that throttle with a stock carb ? |
Author: | DmaxHunter [ Tue Sep 23, 2014 6:32 am ] |
They make one for stock carbs |
Author: | baron von [ Tue Sep 23, 2014 6:33 am ] |
I don't see why you couldn't use with stock carb - i used stock cable with handle and PD EFI, I had to remove about 3/8" from housing on cable to get best results at the throttle body end of cable for the EFI |
Author: | Pulpwood [ Tue Sep 23, 2014 9:38 am ] |
The end was a little smaller, but I've had no problems with it coming out once I zip tied the black hosting to the motor and clamped it down with the clamp. |
