mudbuddy trim issues....
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=56840
Author:  dcmab [ Mon Sep 22, 2014 7:02 pm ]
Post subject:  mudbuddy trim issues....
Hey all. 35 mudbuddy hyper drive. Having some trim issues...
Hunted saturday morning... the boat sat out from midnight till 9 am in pouring rain. When I got done hunting I pulled up to the ramp. The trim didnt work. I tried it about twenty minutes later after everything was said and done and it worked fine. About two hours later the thing didnt work again. Now it wont work at all and the relay makes a vibrating buzz noise. I was thinking the relay was bad and replaced it. Nothing. I was getting 12 volts at the hot wire on the switch. and only 2 on the output. I attempted to jump it and nothing happened. After you play with the switch and trim a bit the relay will stop responding and it wont get any power.
Opinions?
Author:  Smoke [ Mon Sep 22, 2014 7:35 pm ]
Post subject:  Re: mudbuddy trim issues....
Could be the ground could be the switch. Is it a merc trim? If it the merc trim there are two relays did you check them both?
