It is currently Sat Jun 28, 2025 6:59 pm
Reply to topic  [ 10 posts ]
 gtr trim?
Post gtr trim?
2011 35 gtr. Get to launch this morning and go to trim motor up to take bracket off and get nothing. No click no nothing. Cut wires and reconnected thinking maybe a bad connection but that didn't do anything either. Battery is hot. Anyone had something like this happen before? Any idea?
1754GT 35GTR
Thu Nov 27, 2014 4:04 pm
Post Re: gtr trim?
relays.....I have replace in at least 4 times.
Thu Nov 27, 2014 4:13 pm
Post Re: gtr trim?
Forgive my ignorance but where would I check this?
1754GT 35GTR
Thu Nov 27, 2014 5:13 pm
Post Re: gtr trim?
check out GT website.
7 yr old Boykin Spaniel
ROLL TIDE!!
Thu Nov 27, 2014 5:15 pm
Post Re: gtr trim?
1754GT 35GTR
Thu Nov 27, 2014 9:25 pm
Post Re: gtr trim?
Relays are usually in the battery box. Big fuse looking things.
HOTSAUCE170 wrote:
Sat Nov 29, 2014 9:08 am
Post Re: gtr trim?
happened to my friend the other day and what i did to repair is take the switch cover off and undo the screws so you can see the wires inside. blue and green should be the up and down if i am wrong on the colors sorry i dont have a motor here to look at and the red is hot and brown is a common (ground) use a jumper and go from red to blue and then red to green to protect the jump i actually used a 15 amp fuse instead of jumper wire. this protected all other relays as well. then the motor trimmed up and down so we could install the bracket. this told me the switch was bad. found the cheap little rockers on the switch were broke. the switch also is a reverse polarity switch so you will need to make sure you use the common if it seems to not work hit me up on message maybe i can guide you through.
Sat Nov 29, 2014 10:08 am
Post Re: gtr trim?
shouldnt have a relay if you have the tiller control box.... just sayin
07 16x50 w/ 07 35 gtr
Sat Nov 29, 2014 11:33 am
Post Re: gtr trim?
if its the old style trim its prolly the o ring on the motor side busted and its not working...i just went threw it on a old style i had...i just upgraded to the new style...you can get parts from GT to fix it if you can figure out what is wrong
Sat Nov 29, 2014 11:34 am
Post Re: gtr trim?
Mon Dec 01, 2014 9:07 am
Users browsing this forum: No registered users and 254 guests
