Trolling motor question http://mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=58404 |
Page 1 of 2 |
Author: | pintail_89 [ Tue Dec 02, 2014 7:35 am ] |
Post subject: | Trolling motor question |
If yall had a 23 x 66 boat, 1/8 sides, 3/16 hunt deck, 6" cat walks, extended deck, 35 gal aluminum fuel tank, solid double bottom, bench seat and pods. What size trolling motor would you put on it? |
Author: | dom [ Tue Dec 02, 2014 8:04 am ] |
Post subject: | Re: Trolling motor question |
wired for 12v or 24v? |
Author: | pintail_89 [ Tue Dec 02, 2014 8:09 am ] |
Not wired yet, brand new boat |
Author: | pintail_89 [ Tue Dec 02, 2014 8:15 am ] |
I'm just asking for a boat that size. What would yall recomend |
Author: | MNGunner [ Tue Dec 02, 2014 8:29 am ] |
For sure a 24V and possibly a 36V. You can always turn down a trolling motor and still get smooth performance. If you have any type of weeds, wind or current having the extra power is nice! I have the largest 12V one on my fishing boat and my next trolling motor will be a 36V 100+ lbs of thrust. |
Author: | dom [ Tue Dec 02, 2014 8:31 am ] |
min of 80 lbs thrust. but i'd prob go bigger |
Author: | pintail_89 [ Tue Dec 02, 2014 8:34 am ] |
Author: | dom [ Tue Dec 02, 2014 8:37 am ] |
i will say i have a 45lb on my 1748 and i really wish i had the 55. no way would i put a 55 on a 2366. a good wind would make that boat a sail! |
Author: | pintail_89 [ Tue Dec 02, 2014 8:42 am ] |
I have a 24v 74lb on my 19x48 but am selling it to get A 12v 55lb. I have a really light hull though. |
Author: | Howdy [ Tue Dec 02, 2014 8:46 am ] |
Get a big one the first time. If you get in pretty good current and your tm don't have enough ass it's aggravating |
Author: | pintail_89 [ Tue Dec 02, 2014 8:58 am ] |
I know |
Part of the problem is that he is a naval architect/marine engineer and he don't want to listen to shit that u have to say |
Author: | TonyGMcElroy [ Tue Dec 02, 2014 10:21 am ] |
Well let him waste his money on tha 55. Then when he decides to buy a 101 or 112 buy tha old one off him cheap |
Author: | 270Handiman [ Tue Dec 02, 2014 10:33 am ] |
Author: | pintail_89 [ Tue Dec 02, 2014 10:57 am ] |
Author: | WestEndAngler [ Tue Dec 02, 2014 12:17 pm ] |
24V, 90LB thrust minimum. my 12V 55lb thrust will not hold me in a good wind. |
Author: | MNGunner [ Tue Dec 02, 2014 12:43 pm ] |
Author: | BassmasterCia [ Tue Dec 02, 2014 12:46 pm ] |
For fishing, as much thrust as you can afford. If you're bowfishing get even bigger than that lol. |
Author: | Will [ Tue Dec 02, 2014 12:48 pm ] |
Author: | pintail_89 [ Tue Dec 02, 2014 1:14 pm ] |
He not listening. I talked to him about it a lil while ago and he says "I don't want the extra weight from the extra battery" I said r u fuking serious, that boat is giant and won't notice an extra battery or two. Then he said something about the space it takes up and once again I said THE BOAT IS FUKING HUGE!!! lol |
Author: | pintail_89 [ Tue Dec 02, 2014 1:17 pm ] |
Should a 55lb thrust 12v be plenty good enough for my boat. 19x48 solid 1/8 hull with a stock PD. Weight affects surface drive way more than an outboard |
Author: | Gros'bec [ Tue Dec 02, 2014 6:23 pm ] |
24v or 36v. In the 90lb thrust range or bigger. That's to much boat for a 12 v 55lb thrust. The wind has a lot grab onto with those high sides. Combine that with a good current and that 55lb will be straining. The conditions you run in play a big factor also. In protect canal with no wind is one thing but get out in the open with some wind and chop it's another. Get the highest thrust you can afford. You'll be sorry if you go to small |
Author: | msm8281 [ Tue Dec 02, 2014 6:49 pm ] |
Screw the trolling motor. What size motor he's putting on Noah's Arc. |
Author: | Tayfu2 [ Tue Dec 02, 2014 7:11 pm ] |
24v 70# |
Author: | pintail_89 [ Tue Dec 02, 2014 7:41 pm ] |
Author: | msm8281 [ Tue Dec 02, 2014 7:46 pm ] |
Man your friend sounds like he knows everything. I sure hope whoever built that for him told him he's a moron for putting a 115 on it. A 200 on that boat would be perfect. A 150 would be the smallest for me only if I couldn't afford a 200. Oh yeah 80-90# 24v. Nothing wrong with 3/16 on an outboard. You don't really have to cut weight with an out board like you do with a 35ho mud motor. |
Author: | BassmasterCia [ Tue Dec 02, 2014 8:01 pm ] |
Might just be me... But I wouldn't have made it a 3/16 hull if I was gonna put an outboard on it. If he hits a stump with that 115 a dent in his hull is the least of his worries.. But that's none of my business. Carry on |
Author: | pintail_89 [ Tue Dec 02, 2014 8:32 pm ] |
Author: | BassmasterCia [ Tue Dec 02, 2014 9:18 pm ] |
I'd say .80-.100 on average. I'm sure there are exceptions going either way. Not saying he shouldn't have built the hull to last, just wondering why he's skimping on power everywhere. Considering he definitely didn't skimp on the boat lol |
Author: | msm8281 [ Tue Dec 02, 2014 9:21 pm ] |
Any reputable builder will use 3/16 on a big boat. They do not want to fix cracks down the road and worry about their reputation. It's also easier to weld. |
Author: | cb5331 [ Tue Dec 02, 2014 9:29 pm ] |
Author: | pintail_89 [ Tue Dec 02, 2014 9:31 pm ] |
Yea he deff didn't skimp on yhe boat. It's a badass rig |
Author: | Will [ Wed Dec 03, 2014 11:46 am ] |
Author: | pintail_89 [ Wed Dec 03, 2014 12:38 pm ] |
Ok so what is thicker than 3/16 I feel like some of yall are making it sound like big aluminum boats with big outboards are thicker than 3/16 your moms house |
Author: | cb5331 [ Wed Dec 03, 2014 12:53 pm ] |
They make plate boats 1/4"+ 3/16 is sufficient for most though, and its not uncommon at all on boats with 150+hp |
Author: | pintail_89 [ Wed Dec 03, 2014 1:05 pm ] |
Author: | SETx Longtail [ Wed Dec 03, 2014 6:11 pm ] |
A 12v 55lb would do fine.... If he put about 4 of them together ![]() A 115 would shove it ok but a 150-175 would be ideal. A 225 console setup would be what I'd go for though. That big of a boat in front of a tiller is gonna be a pain in the ass. As heavy as it is, it should ride good though. Any more pics of it? |
Author: | pintail_89 [ Wed Dec 03, 2014 6:36 pm ] |
Author: | LB200 [ Wed Dec 03, 2014 8:26 pm ] |
12 volt motors do not have enough ass or last any where close to long enough. That big a boat needs a 24 volt in my opinion |
Author: | pintail_89 [ Wed Dec 03, 2014 8:29 pm ] |
Yea well I'm done trying to help him. He doesn't want to listen anything I have to say on the matter, he being hard headed as fuk. He has barely any experience with trolling motors and my dad has about 40 years experience with them bc he bass fishes religiously or at least use to. So he knows a thing or two on what size boat needs what size trolling motor lol your moms house |
Page 1 of 2 | All times are UTC - 6 hours |
